Catchcan setups with F/I
Old Aug 29, 2005 | 12:51 AM
Boostaholic's Avatar
Default Catchcan setups with F/I
So I have a catch can, and a breather.
I want to remove the breather from the driver side valvecover and block that off, then attach a catch can line to the pass side cover and run that to the catch can?
Or is there a better way to set this up?
Also, should I try and get a vac source on the other side of the catch can or will simply routing the line to the valvecover be enough?
Old Aug 29, 2005 | 08:45 AM
libertine1015's Avatar
Some guys go from the can back to the intake with a check valve to keep the boost out of the can. Or you could use your inlet at the turbo (many have a fitting or you can install one) to draw air through the can.
Old Aug 29, 2005 | 11:51 PM
BOONE's Avatar
I use the inlet by the filter for vacuum," Its alot stronger" and I removed the pcv and run a gas filter for vapor. I change the filter when dirty before there is any fallout in it. I have never even seen oil in the can at all, just vapor in the lines and filter. Before this it used oil if i hammered it hard alot, to the point where my intake was very oily, and i had to check my oil often. Im probably going to get a air/oil separator and splice that in too.
