How much is the ATI Super Damper
http://store.summitracing.com/defaul...2.asp&N=400250
No luck on the key / pin set yet....
$500 for a damper!!!
I think I'll just buy the stock replacement.
Here is the pin kit:
http://www.atiperformanceproducts.co...ex_ls1_pin.htm
As for the 6rib setup, it has not been to effective in the past. With bolt problems,and slippage problems. I honestly can not tell you much. I am sure other can chime in with the problems they had.
I guess I just look at things a bit different. I myself would rather spend the little bit of extra money and not have to worry about redoing it later, and taking the chance of causing damage to somthing else.
If you do just go with the stock setup, few things to keep in mind-
you will need to pin the crank as well.
Need to shorten the bolt a bit. (new bolt)
Make sure you clean the threads real good on the crank and the bolt. (oil free) and use loc-tite.
I don't mind taking out the procharger and replacing the pulleys later on down the road when I can afford the 8-rib setup. I am like you- I would rather spend a little more extra now, but unfortunately, I simply don't have the funds to do so.
Thanks for the help, I do appreciate it. The pulley already has 3 pins in it, so I am assuming the former owner pinned it to his damper, so all I will have to do now is drill the holes for those pins in the stock damper, and then pin it to the crank.
(had to try lol)... The bolt I have is also an ATI supplied bolt that the former owner of the system had, so I assume it is already short enough to fit. So do you sell the 917242 balancer for $475? And I see you carry the pin kit too, P/N 918993. Are they in stock? And do you also carry the 1.7 ratio Cran rocker arm kits, P/N 144750-16?
Mark
Mark
