Question??
Old Sep 1, 2005 | 03:23 AM
CarolinaWS6's Avatar
Default Question??
I have a Question i want to make 700 rwhp on pump gas i want to be able to make it with a 347 is it possible if so what will it need i plan on running a TTi turbo setup ??
Old Sep 1, 2005 | 03:25 AM
99SS-T's Avatar
You need dual intank pumps prolly new feed lines to the engine. fuel rails FPR 60# injectors and more the likely methanol as it makes everyhtign alot safer. GL
John
Old Sep 1, 2005 | 07:02 AM
shawn_c992001's Avatar
damn that's a big number
Old Sep 1, 2005 | 07:07 AM
EPP's Avatar
EPP
Check out the twin turbo Corvette and also the black Trans-Am on my website in the project car section. It will give you a good idea of the parts required. We kept the stock cubic inch and the stock crank on both cars. Bob
Old Sep 1, 2005 | 08:15 PM
Bryan Wilkinson's Avatar
You should ask your neighbors
Drop me a line lunapark@perigee.net
Old Sep 4, 2005 | 01:58 AM
blackfang's Avatar
I know MightyMouse made over 700 on pump gas in his 346 block. I am not sure what pump set up he had.
Old Sep 4, 2005 | 03:14 AM
can i make 700rwhp with a 383 low compression and a TTI race turbo kit??
Old Sep 4, 2005 | 03:35 AM
red90cobra's Avatar
yes you can
Old Sep 4, 2005 | 03:38 AM
StoleIt's Avatar
NKAWTG...N
easily. what trans and rear end setup you going to run? if your going m6/10bolt (not suggesting a 10bolt but...) you'll hit that easily. going th400 through a 12 bolt and its gonna be more effort.
Old Sep 4, 2005 | 03:53 AM
i have 4L60 Rossler stage 3 tranny its rated at 900 ft pounds and not sure on the rear end. what do u suggest i do about heads and cam
Old Sep 4, 2005 | 05:17 PM
what kind of heads do u suggest i do
Old Sep 6, 2005 | 06:31 PM
anyonE??
Old Sep 6, 2005 | 07:24 PM
paspar2's Avatar
AFR if you have the money...
Old Sep 6, 2005 | 08:43 PM
Reject's Avatar
700 is a shitload for the street!
