FAST 90/90 & a turbo?
Old Sep 1, 2005 | 10:48 AM
Shane_G's Avatar
Default FAST 90/90 & a turbo?
I thought the FAST 90/90 combo worked best for NA engines, but a fella I know keeps telling me I need to go with the FAST 90/90 on my turbo 408 setup.
I'm confused
Old Sep 1, 2005 | 10:51 AM
transam1998's Avatar
Turbos like to flow just like everything else. You may not need it as much, though with F/I since the air is being forced into the manifold to keep it at constant pressure.
Old Sep 1, 2005 | 11:38 AM
dlevene's Avatar
You'll be happy if you put a 90/90 set up on.
Old Sep 1, 2005 | 01:57 PM
Shane_G's Avatar
So, is there a FAST 90mm throttle body and a Nick Williams 90mm throttle body? What is the difference?
Old Sep 1, 2005 | 02:02 PM
2000 Tran Zam's Avatar
both are 90 mm, just different companies, like headers.
Ive got 90 mm intake and tb going on my 408 turbo setup.
Old Sep 1, 2005 | 02:08 PM
LSONE's Avatar
nick williams > fast TB
Old Sep 1, 2005 | 02:14 PM
gnx7's Avatar
If guys are making 850rwhp+ with LS6 intake and ported stock TB being forced fed by a turbo/supercharger why drop the $1200+ on a FAST 90/90?
There is a turbo Vette making 1000hp on LS6 intake and ported stock TB....
What are your goals? HP and et/mph?
I would put the money elsewhere personally.
Old Sep 1, 2005 | 02:24 PM
Shane_G's Avatar
That's what the engine builder said.
I just want to make sure I'm not skipping anything while my engine is getting built.
Old Sep 1, 2005 | 02:39 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm making 750rwhp thru a stock ported TB and a stock LS6 intake. When I go to the sheet metal intake I have coming I'm not putting a stock TB in front of it.
ABeasst's Avatar
for half that you could do a GMPP single plane intake w/ 90mm TB and have better distribution
Old Sep 1, 2005 | 02:46 PM
LS1Tech Co-Founder
R uu talkeen to meee?
From what I saw, I would need to lower my engine a few inches to fit a simple plane/elbow setup and fwiw I am getting the intake super cheap so it's not a cost issue.
Old Sep 1, 2005 | 03:04 PM
drozd_ws6's Avatar
Default fast 90mm tb
The fast 90mm tb is junk on a forced induction setup. It has a very weak spring combined with it's occasional tendency for the blade to stick!!!! In my experience once my charger stated to blow a little boost into the motor the fast tb liked it so much it decided it didn't want to close!!!
Old Sep 1, 2005 | 03:06 PM
ABeasst's Avatar
If you contact AaronL you can get a sheetmetal elbow that clears the stock hood. so no need to lower anything
Old Sep 1, 2005 | 03:10 PM
LS1Tech Co-Founder
Have him send me one and I will test it against my sheetmetal intake. I don't know who that is.
Old Sep 1, 2005 | 03:12 PM
Shane_G's Avatar
So do yall (yea, I'm from the South) think I should go ahead with a 90mm TB?
Old Sep 1, 2005 | 05:11 PM
ABeasst's Avatar
check out this post https://ls1tech.com/forums/lsx-parts-sale/282822-custom-ls1-efi-intake-manifold-w-elbow-fuel-rails.html
Old Sep 1, 2005 | 06:26 PM
bumpin_records's Avatar
so my question is , Is it worth the money goin with a fast 90/90 set up vs a ls6 and ported throttle body or even a after market 80+ throttlebody? Or should the money be spent elsewhere?
Old Sep 1, 2005 | 07:09 PM
qqwqeqwrqwqtq's Avatar
Well, 3in induction tubing will carry you well over 1000hp, so unless you're at the point where you are being throttled by your induction tubing there will be no gain over a stock throttle body.
If you are being throttled by the 3in induction tubing, than you would gain power with a 90, but only if you ran 3.5 or 4in induction tubing, and at that point you are making the kind of power I have no experience with.
