sorry, but...
Old Sep 5, 2005 | 02:48 AM
Turbo LS1 SS's Avatar
Default sorry, but...
another one of those "how much boost can i run" threads...
what i have.... 2001 ss, built bottom end (probe pistons, scat rods, stock ls1 crank, arp rods throughout), stock 241 heads, good springs, shitty 220/218 564 114 cam.... sts turbo, gt67. 8.65 CR. 3" OBX fmic
#1 thing is conservativity/safety of engine....
right now its tuned at 8psi, conservaticve.
over winter, installing meth injection.
what psi can i saftely run with this.....
and, will this psi be efficiently supported by my gt67....
with whatever psi suggested, what power can u predict if i made 440 @8psi and only 200 on the engine
sprry of this post sounds stupid, its 346am, and im drunk
edit: also, if i get a good cam, what other types of gains can i expect?
Old Sep 5, 2005 | 05:39 AM
Slowhawk's Avatar
LS1Tech Sponsor
With that compression and Cam you should be running 10lbs minimum.Also an intercooler or Meth is a must but I'd recommend the intercooler.I would say 14lbs/intercooler would be perfect for pump gas with your setup.
8lbs switched to 14lbs should net another 130-150rwhp.
Old Sep 5, 2005 | 11:57 AM
i have an intercooler already...im gettin meth when i retune/up boost
Old Sep 5, 2005 | 03:36 PM
ttt.... more comments on this please...kthx
Old Sep 5, 2005 | 03:40 PM
eviltwins's Avatar
My comment is I would have never ran probe forged pistons, but I'm thinking you have the car together already so it's too late to change that. I personally wouldn't take it past 14 psi, I broke probe pistons on a 302 because those ones had basically zero material under the crown, and the tolerances were pretty wonky on all of them.
Old Sep 5, 2005 | 03:46 PM
ya my ******** engine builder went behind my back and bought something other than what i told him....
wrong pistons, rods, cr, and cam....... what r u gona do...
but ill take that into account...thank u
Old Sep 5, 2005 | 04:45 PM
LSONE's Avatar
sounds like you need a very large discount, as those are about the cheapest products you can buy.
Old Sep 5, 2005 | 05:05 PM
mdhmi's Avatar
Not pay the builder. Sometimes you get stuck though.
Mark
 Michael S. Palmer
