Surge valve/ Bypass
Old Sep 7, 2005 | 06:47 AM
SS LeadFoot's Avatar
Default Surge valve/ Bypass
What surge valve comes on at lower RPMs? Right now I am running a Turbo XS RFL BOV and it comes on at 1500, I know now why I can't run it though. I was thinking of getting the Mondo bypass valve since everyone says it is loud but at what RPM can you let off the gas and hear it? Is there any other options besides Vortech and ATI for these things? Any sound clips?
Old Sep 7, 2005 | 08:10 PM
BOONE's Avatar
The ati bypass is adjustable, and i have mine set so it closes soon as I go wot. It opens soon as it senses vacuum, "when you let off of wot." I dont hear mine unless its reved up enough, cars pretty loud. If i had it to do again id get the mondo, sounds cool and its cheaper too.
Old Sep 7, 2005 | 08:40 PM
DeltaT's Avatar
I have the Mondo and it dumps right back into the blower inlet. I can not hear it at all, but I can see on the datalog when it dumps, because my recorded MAP spikes down every time it opens.
Of course, things are a bit loud at 6100rpm... but I don't hear any of the chirping and gurgle that other people talk about.
Jim
Old Sep 7, 2005 | 08:53 PM
frcefed98's Avatar
The mondo is open all the time except when getting into boost/wot conditions, then it slams shut, and comes preset from vortech for just about anything on the road.
Old Sep 8, 2005 | 01:11 AM
DeltaT's Avatar
frcefed98,
How many turns in do you adjust your bypass valve screw?
Thanks,
Jim
Old Sep 8, 2005 | 06:33 AM
Where can I buy a Mondo valve? I herd you also have to buy an adapter fot it to fit.
Old Sep 8, 2005 | 07:11 AM
frcefed98's Avatar
Jim it was good to go right out of the box, no need for adjustment, KP has my old s/c set up and is doing great with it.
SS lead foot, summit racing, and you can get the flange directly from vortech its about
12 dollars.
Old Sep 8, 2005 | 04:31 PM
DeltaT's Avatar
SS leadfoot - You don't have to buy the flange but it is a very clean fitting piece and is thick enough to be welded to something. I ended up using it as a precision spacer.
frcefed98 - thanks!
Jim
