Log header vs truck manifolds
CMC
CMC
truck manifolds save alot of time too, less stuff to fabricate for your hot parts. Also won't have to worry about them cracking. You can also get to the spark plugs very easy with them.
CMC
the ohio boys said they had to fab something up as it melted off or something like that. only thing i think it could be is one of the slip joints or something, i might just insulate that and see what happens, hopefully it holds up.
Finally wanna be fast
You loose A/C and have to relocate the alternator to the top.
The power steering lines have to be either bent in a way to clear the manifold or have new ones made. I was able to bend mine around and has not been an issue. Now as far as the steering shaft goes. It is close to the manifold and I was originaly going to make another shaft like I did on the Formula. But I have been running the stock shaft with the manifold heat shields in place and have not had any issues. These manifolds do glow red in high power/load situations.
These are not "race only". Ask me how I know?
how do you know
ed
http://stenodracing.com/milan/MM/Ste...et_Driving.wmv
CMc
Has anyone used Flipped GTO headers? We have to flip them to use the GenTT twin kit and we lose nothing. and about Nine Ball's comment of the outlets. The GTO headers are just that. I was going to use fliped up GTO manifolds to run a twin kit. However I need to make a adapter to pull the drivers side header forward cause it hits the brake booster.
