what MAP do I need for new setup?
Old Sep 8, 2005 | 09:26 PM
NYSS Guy's Avatar
Default what MAP do I need for new setup?
Okay, I'll list some details on the setup, but I'm not sure if I need a 2 bar setup, or a 3 bar setup. Also, aside from changing the MAP sensor, is there anything else that needs to be changed? I did a search, but I didn't find what I was looking for.
LME forged 370 8.5:1
Patriot Perf. 6.0 heads
custom cam
stock LS6 intake
I plan to run 15 psi on the street, and probably 18-19 at the track. Thanks for any advice.
Old Sep 8, 2005 | 09:48 PM
slow's Avatar
more than 14.5 approx, need 3 bar.
Ryan
Old Sep 9, 2005 | 02:11 AM
Skunkworks's Avatar
If you are going SD and boost is 14 PSI or less stick with 2 bar. When you jump to 3 bar PCM looses allot of resolution.
Mike
Old Sep 9, 2005 | 08:00 AM
NYSS Guy's Avatar
Does the PCM need to be changed to run 3 bar??? Or would I just change the MAP sensor, and tune it with HPTuners?
