Phamspeed turbo leak
Like Pat, said above. Cut the flare end off the oil supply fitting on the turbo, add N2O jet and screw your oil supply line back on. I'm using an .109 restrictor, no smoke except after braking real hard.
Got a .032 N2O jet, drilled it out with a .109 drill bit.
To be used on a GT42's on LS1s only and only if you are filling up your DP with oil....don't know about other turbos. Garretts are known to be smokers out of the box because of the oil supply issues. I only recommend this if you have a GT42 with a smoking issue and you have your oil drain line figured out. I take no responsibility for smoked turbos(lack of oil supply)
J
J
Originally Posted by 69firebird
hm,
this is hte one thing that has me concerned with the new turbo
ed
ed
Originally Posted by 1a-play
what if you put in 2 drain lines back to the pan- t off on the turbo outlet line?
