Something differenr Sir? - An electric supercharger!!!!!
The exhaust gases turn and impellor (ie a turbine) which then rotates compressing the intake air.
And I'm not talking about where in the rpm's the turbo kicks in, I'm talking about the lag time a turbo produces after a stall period.
No matter where you are in the rpm's (so even well within the boost range) if you lift off of the throttle pedal from WOT the sudden decrease in exhaust gas velocity will cause the turbo to stall, if you then apply full throttle once again there will be a momentary LAG before boost is once again produced.
The only way I know around the problem is the anti-lag systems WRC rally cars use.
You could also mount your alternator/generator to the accesory drive of the APUI believe you could make this all fit in a race car and be around 225-275 lbs worth of goodies.
If I win the lottery I am building one just for the heck of it
Now I know there are cheepy electric fans that claim to increase BHP. But I'm not talking about them, for FI you need something that compresses not blows.
BUT
A Centrifugal supercharger is mearly a compressor driven via a belt from the engine. So what if you connected that belt to a high powered elctric motor instead.
In the case of the LS1 the engine operates from 1500rpm to about 6000rpm. These are easy speeds for an electric motor to acheive. Obviosuly the motor would need to be powerful enough to counter the load of compressing the air.
Cons:
Now the down sides would be the electic motor. As it will be fairly large and heavy in its self. Also the power consumption of the thing. Would it require more BHP from the engine than the blower does being driven directly from the engine?
And maintance with the electric motor brushes. Although if you're into model cars you'll know the benifits of the brushless motors, which practically never wear out.
Pros:
That the blower is no longer driven directly by the engine. So as long as the electric motor was effiencent enough you would produce more BHP.
Also using an electronic control device you could have the blower producing maximum boost from a little above idle. Thus no longer being engine rpm dependant. Or indeed any lag as a turbo suffers from.
In addition I suppose by having full control of the blower rpms you could simply via a switch on the dash board alter the maximum boost instantly. Or indeed switch the blower off completly if you so desired. (fuel saving).
So far I have done NO research on this, so I don't know whether it has been tried before or not. Any comments or views on it are most welcome. Even if you think I'm bonkers!
