How much boost are you guys running?
Old Sep 13, 2005 | 07:49 AM
Cyborg's Avatar
Originally Posted by z28adiction
How much boost do u guys run in here who have a procharger kit? I plan on running a forgered 402 with afr 225cc heads and a D-1sc supercharger. just wondering what number you guys are getting out of ur procharged cars?
Yea i was planning on 9 and hopeing to get around 550 at the wheels
W/a 402, 225 AFR's, & P1 @ 4psi, I was at 557 CRWHP....So if your planning on a D1 @ 9psi you should easily exceed your goal of 550
Old Sep 13, 2005 | 09:23 AM
SS LeadFoot's Avatar
I agree with getting the 8 rib and the spring tensioner from SDCE
Old Sep 13, 2005 | 06:54 PM
z28adiction's Avatar
yea the 8 rib is deffinately a must
Old Sep 13, 2005 | 08:26 PM
nitrorocket's Avatar
Any aftermarket piston 2618 forged piston is good.
Old Sep 14, 2005 | 12:45 AM
SRZ's Avatar
SRZ
So what kinda numbers can I expect even though I'm not a LS1.
D1SC 12-14psi
LT1 396 -31cc dished 8.1:1cr
LT1 heads flow 275-194ish range
Cam 232/242 .544/.560 .@.050 115LSA
60lb Motron injectors racetronix 255 pump
FLP headers GMMG
D&D M6 tranny & Street Twin clutch
I could get very detailed but that should be enough to get a baseline answer I think. Think I could squeeze 600-650rwhp out of that?
Thanks
Old Sep 14, 2005 | 03:12 AM
GTBMad's Avatar
i know boost has nothing to do with a car being street leagal i was just wondering if that car was a street car or a car he uses for strictly racing
The car is street registered, legal is another issue
Yes we do drive it on the street and and will be racing shortly
Old Sep 14, 2005 | 06:49 AM
Nice I hope i never run into your car on the street. haha
Old Sep 14, 2005 | 07:09 AM
Slowhawk's Avatar
LS1Tech Sponsor
Like Cyborg posted above.His 402 with the tiny P1 oushing 4lbs hit's over 550hp I see no reason why a D1 couldn't push over 700rwhp on pump gas on that 402
BTW-the 55lber's will be too small and plan on a whole fuel system.
Another note -I run 12lbs on my stock motor
Old Sep 14, 2005 | 08:38 AM
yea i plan to buy the ls1speed fuel sistem they say can support 700 hp and then ill get bigger injectors
Old Sep 14, 2005 | 01:02 PM
moehorsepower's Avatar
D1SC 12-14psi
FLP headers GMMG
Thanks
Mine:95 LT4
648 RWHP/612 TQ pump gas on 12 lbs of boost
722 RWHP/713 TQ on C-16 and around 16 lbs of boost.
Just a word of advice, I started with 50lb Lucas injectors and ran out of injector. I now have 80lb delphi injectors and my duty cycle is at 79%. You might be close with the 60 lb..
Old Oct 6, 2005 | 01:02 PM
Should i go with the cast iron w2w supercharged short block they sell or buy there supercharged short block from them but tell them to use the ls2 aluminum block instead of the cast iron one when they assemble it. I am going to ask them whether i should use the ls2 block or not when i order it because there the proffesianals, but i would jsut like some feedeback from you guys.
