How much boost are you guys running?
Check out the car above. Bob
-SLP zl402 short block low compression 9:1 compression
-AFR 225cc heads with rev kit and roller rockers
-procharger d-1sc kit with new bigger intercoolers
-comp cams XR269HR-14LS1 Hydraulic roller camshaft .525/.532 lift with 114 degree seperation 1300-6300 rev kit
-quicktime performance headers and timing chain cover with larger oil pump
s-lp heavy duty timing chain
-fast 90/90 set up with ls1speed fuel package set up thinking about buying fast fuel rails intead of the ls1speed ones.
-Be cool radiator to cope with the procharger overheating problem ive heard about.
-going to upgrade to 55 lbs injectors from the 45 lbs ones that come with the procharger kit
-Borla cat back exhaust
-MOser 12 bolt with posi and 33 spline axles and carbon fiber drive shaft
-msd blaster coils with msd wires and NGK TR6 plugs fir a cooler spark
- i plan on installing a full BMR chassis setup later on.
Make Sure you include a ATI superdampner and 8 rib drive. Take those Fast $$$ and put them towards SDCE tensioner setup.
Hope you are not going to run your stock clutch............
And also are LS1 seed products quality and reliable.
The problems i see here since ive done it and moved on......
The D1-SC is going to run out of steam... ie not going to be enough if you ever plan on pushing for more then 550rwhp.....
2nd
why are your running a cam that small and with that little lift in a motor that huge and heads that can flow that well??? it a waste.....
The Fast stuff is a big waste sospent your $$ on a LS6 intake and the rest some where else...
another... why are you going to waste yourmoney again onthe quicktime timing cover...... u plan on changing cams each week??? thats what its for.... so the balancer doesnt have to come off each time you change the cam....
When you order the short block have themKey the crank so the balancer doesnt spin on the crank.... or have them pin it.
Use the Motron 60# fuel injectors... there pretty easy to tune....
and the number one thing is get a good tuner...... the tune is what will make or break you.
I recommend SDCE's spring tensioned 8 rib setup if you dont want belt slip....
Kyle
2nd
Kyle
Also had another F/I buddy making just over 600 on a P1 but it was at its limits.
