SPAL fans install... Questions.
Mocking the fit up it appears I'll need to have the fans pushed up as far to the pass/top as I can get them to avoid the Procharger head unit hitting the back of the driver side fan itself (not the shroud).
Guys that have these fans - is that roughly where you put yours ? Should they be more centered on the radiator ?
Also, any tips on mounting them up ?
Thanks for any tips installing these bad boys. I'm hoping to fix the overheating in hours of summer traffic.
Thanks,
Rob (Bad30th)
http://store.summitracing.com/partde...=KeywordSearch
Thanks for any help.
Cheers,
Rob (Bad30th)
I'm gonna try to make a sheetmetal mounting shroud to mount them to, that will hang in the 4 factory mounting slots and ride in the drip tray behind the radiator - and it will have the two fans offset, driver side higher than the pass side... I could use insulation to seal the sides of the shroud to the fan shroud... Similar to the ATI shroud but with holes to mate to the SPAL shroud instead of a single 16" fan. Muhaha, think it will work ?
That's the best idea I have so far...
Rob (Bad30th)
Please help give me some ideas before I go buy a high volume 16" SPAL fan to put on the ATI shroud like I should have in the first place...
Pics from someone who has installed them would be a real help here.
Cheers,
Rob (Bad30th)
i used a aluminum yard stick on the bottom of the shroud, and used stock rad. bottom slots.
the top of the shroud is held by the ati rad. support.
and thats it. of course you have to trim around the driver side fan to clear the ati inlet hat.
also some people had to move tha radiator forward a bit for the fan to clear, but i didnt.
just keep trying different things until you find what works, thats what i do when i am in a jam. i also searched on the forum and found more then enough info to do the install with no problems.
hope all goes well.
Did you use anything else to hold the fans in place ? (Bushings/etc) to keep from damaging the rad fins if the fans bounced around ? The shroud seems kind of flimsy, if I install them together "as-is" I will probably reinforce the seam where the two fans meet to keep it more stable.
Jest read you didn't push your radiator forward at the bottom ? You guys are giving me some hope here... Now to find a metal yardstick... Think a fabric store might have them, or Home Depot ?
Rob (Bad30th)
The pic isn't very clear as to the install, but everythings clears without any rubbing, etc. even though the SPAL 9 inch is about 2 1/2 inches wide. IMO the install looks stock.
http://pg.photos.yahoo.com/ph/dlands...ec.jpg&.src=ph
The only thing I don't like is that the two fans push so much air, they really kick up the dust and make the engine bay very dirty, very fast.
Anyone know how much the ATI supplied 16" fan flows ? The SPAL 16" flows ~2400 cfm, the dual 11's flow ~2700 cfm.
I've been mulling this over and I think just trying to mount the dual fans without enough support is a bad idea, they flex a lot and will be moving/bouncing around against the rad fins... I'm still thinking I would need to make a sheetmetal mount for them that has support in the center and all the way around the fans shroud...
At this point it's pretty clear that if I use a flat shroud to hang the SPALs on the factory mounts (about 1" back from the fins) and don't have the fans pushed all the way up against the rad fins it won't clear the blower... I can't push the rad forward at all, A/C condenser is in the way (I still have A/C, which is laughable because every time I use it I overheat
).I don't want to have to buy the 16" SPAL fan but it appears that would be the easiest way to get the car back on the road, with a reasonable increase in cooling capacity...
I thought I did enough research on this, gaaaaaaaaah.
Looks like I would need to trim the pass top of the shroud for the trans cooler output from the radiator too... Right now I'm trying to sketch something up that will use the factory mounts and bend around to mate the fans 1/4" or so from the rad fins...
I've seen pics of a SOM TA with them installed, so I know it can be done... I just want to make sure they dont bang up the fins from not being mounted sturdy enough...
Rob (Bad30th)
http://www.srbymichael.com/manufactu...pal/fans.shtml
As for my car (see fan pics in previous post), the Extreme 16 and 9 inch keeps the car from overheating while driving in stop and go traffic, but if I turn on the air and let the car sit and idle (in 90 + degree weather the temp will climb to 210 within 5 minutes).
Turn off the air and it will drop back down (I have a Mezeire electrice water pump which flows pretty good at idle).
Next summer I am going to mount a fan on the AC condensor too, that should keep the car cool, when I turn on the AC.
HTH.
BTW, the rigidness of the perimeter housings on both the Spal 16 inch and the 9 inch is pretty stiff, so there's no worry about the fan blades of either getting into radiator fins.
