this is probably beat to death... maxed fuel system
i think it will easily be 800 at the fly wheel for my coming motor..
when will i have to upgrade to a fuel cell with a large pump and braided lines and new rails?
im checking up on the D-1sc kit and to me it looks like every one under estimates its ability
D-1sc with the twin IC's and a small Direct port 100 shot max sounds like magic to me
of course when i mean maxed out..my fp went from 58 to 70psi and by redline was below 55psi
stock lines == nono
You can get anything you want out of a setup if you go bigger lines, rails, pump. Pick your poison. Tank really has nothing to do with it. Sump a stock tank and you can do what you want.
Trying to nickle and dime a fuel system is the worst possible idea IMHO. It only takes one hiccup to put a hole in a piston.
stock lines == nono
