Who makes this supercharger!?
From there it is flatlined until 6500rpm as my pcm won't read any higher.
It was probably well over 65lbs/min at the power peak.
The roots blower should get a big mass flow increase in very early in the rpm range. Then it will steady out.
It won't make the peak power of a good centrifugal but will have much more low end.
For some cars this would not be of any advantage.
For instance with my 2800PI Stalled a4,
At any WOT punch I flash up to 5000rpm and pull from there. So I see an instant 7psi and build to 10PSI.
A m6 or stock stalled a4 would benefit more from the off idle punch of the roots blower IMO.
Steve
[ December 17, 2001: Message edited by: Steve Underwood ]</p>
okay, Reverse, maybe! <img src="gr_grin.gif" border="0">
besides, what's so bad about a power dome hood? And nitrous oxide makes a great intercooler! <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
<img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
With this setup, launch at 1500 and shift at 5000 to get into the higher gear ratio to take advantage of the low end boost.
Who wouldn't want to launch lower and shift at a lower rpm and run quicker times?
