head gaskets and cam
Old Dec 7, 2001 | 10:28 PM
2bseen's Avatar
11 Second Truck Club
Default head gaskets and cam
I'm putting a vortech v-9 on my 01 firehawk that already has a lunati 224/224 561/561 112 lsa cam i'm taking the heads off to polish and port will this cam work ok and what head gaskets should I use?
Old Dec 8, 2001 | 04:46 PM
2bseen's Avatar
Default Re: head gaskets and cam
ANYBODY KNOW
Old Dec 10, 2001 | 08:26 AM
1dirtyZ's Avatar
try tbyrn ( not sure though. if not try augustino racing), i belive they have a set of gaskets for boosted engines as well as reusable head bolts.
Old Dec 10, 2001 | 08:36 AM
2bseen's Avatar
thanks
Old Dec 10, 2001 | 10:28 PM
nxpowerr's Avatar
Use the 2002 Vette head gaskets. They are a steel gasket so you don't have to worry about them too much. If you have stock displacement motor, 112 l/s is too much. You need to go down to a 114. I personally like the comp cam .224 .228 .535 .538.
Old Dec 10, 2001 | 10:55 PM
minty's Avatar
stock head gaskets work the BEST....for any application
Old Dec 13, 2001 | 01:55 AM
MNC5's Avatar
Talk with ARE they have some pretty good experiance with boosted applications and head gaskets. I would stud the block as well...
Good luck
