White smoke on WOT?
Old Nov 15, 2001 | 02:54 PM
Jerry's Avatar
Default White smoke on WOT?
Is this just unburnt fuel?My air-fuel is 12.4-12.6 so im not running rich. Sometimes i smell antifreeze when driving but its usually just for a few seconds then it goes away. Anythoughts?
Old Nov 15, 2001 | 03:36 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default Re: White smoke on WOT?
What psi you running or bottle hp? White smoke is Coolant <img src="images/icons/frown.gif" border="0"> . I have trouble with smoke color cause blue smoke is oil. I cant tell the dif lol. If you running boost maybe you lifted a head.
[ November 15, 2001: Message edited by: Cool28 ]</p>
Old Nov 15, 2001 | 03:37 PM
AgaveCorvette's Avatar
uh oh. You have coolant getting into the combustion chamber. Not a good thing.
Old Nov 15, 2001 | 03:45 PM
Cool28's Avatar
Is this Jerry(Gonepostal)
Old Nov 15, 2001 | 06:51 PM
BIGBOS's Avatar
I have a slight whisp of white smoke...not solid white...but more of a grayish...lasts for about 2 seconds on a cold start...
Old Nov 15, 2001 | 07:48 PM
Jerry's Avatar
Well, my coolant seems full and i dont smell antifreeze at all coming through the tailpipes,maybe it wasnt white,but it was a light color,maybe greyish or very light blue? God, i really hope its not coolant. Also,its not dense smoke.Real thin....
[ November 15, 2001: Message edited by: Jerry ]</p>
Old Nov 16, 2001 | 01:29 PM
Kenny H's Avatar
A friend of mine was blowiong out whitish smoke out of his '00 T/A 6 speed a few weeks back at ETown. Turns out its rings. I believe their is a TSB for '99-'01 LS1s about that....
Old Nov 16, 2001 | 04:39 PM
Cool28's Avatar
I could be saying alot of **** but I'm not <img src="images/icons/wink.gif" border="0"> . Could the impeller for the s/c be leaking oil? That has oil in it right?
Old Nov 16, 2001 | 05:30 PM
Jerry's Avatar
i dont know i need some more wot runs to see exactly whats going on, another guy with the vortech setup has the same thing,and he has alot more miles with it than i do, so hopefully its not a bad thing, i really hope not rings, the oil is fine.
Old Nov 17, 2001 | 12:29 AM
Jacobi's Avatar
greyish or very light blue...well atleast it's not a head gasket but it does sound like piston rings. Or maybe someone snuck in a two stroke, j/k!
Old Mar 25, 2002 | 12:50 AM
jhelms's Avatar
So what all could this be:
1) Head gasket
2) Rings
what else?
Old Mar 25, 2002 | 12:59 AM
1dirtyZ's Avatar
pcv sucking oil???
valve seals?
Old Mar 25, 2002 | 05:53 AM
Black LS1 T/A's Avatar
Moderator
White smoke is indication of a blown head gasket.
Other things to check/verify this.
Is your coolant level low, particularly after making several WOT runs? If you are in the initial stages of a cracked or ruptured head gasket, it may take a LOT of hard driving to see actual lower coolant levels.
Take of the radiator cap and top the coolant off. Do you see bubbles stirring at the top?
White smoke (vapor burning off) when the car is not yet warmed up is normal. Vapor at ALL temps is coolant passing into the combustion chamber and burning off as steam and exiting the exhaust.
Black smoke is usually fuel related problems and blue smoke is usually oil related.
White is water/coolant related.
Old Mar 25, 2002 | 05:16 PM
Cool28's Avatar
lol
Old Mar 25, 2002 | 06:11 PM
red ws6 99's Avatar
You can get white smoke with to much fuel, although on an EFI car thats the last thing I would look at. Most likely a coolant problem.
Gary
Old Mar 26, 2002 | 12:58 AM
Sky042's Avatar
See what happens to people who don't drive their cars <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . Bring it to the park on the 7th let someone see the smoke or if you want I'll come by this week and see what it looks like to me.
Kyle
Old Mar 30, 2002 | 02:03 PM
Fast SS on TNT's Avatar
I had the same thing happen to me....I was whipping the hell out of a viper and the same thing happened to me....you have a blown head gasket bro...sorry to say.
see my cars at this link
http://camaroz28.cardomain.com/id/badcamaromaha
