Turbo Cam?
Old Dec 4, 2001 | 05:56 PM
wicked 98z's Avatar
Default Turbo Cam?
Would a 224/228 with a 535/536 lift work with a turbo? If not what would be a good cam to use?
Thanks
Albert
Old Dec 4, 2001 | 06:06 PM
LJ_Z28's Avatar
Default Re: Turbo Cam?
Albert, you got a turbo man???
You sorry dawg... <img src="images/icons/grin.gif" border="0">
Old Dec 4, 2001 | 06:28 PM
wicked 98z's Avatar
99% there. Putting the final touches on the deal <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Dec 5, 2001 | 12:03 AM
HouseofSpeed's Avatar
Albert..small overlap and shorter on the exhaust. Makes for a killer turbo cam.
Old Dec 5, 2001 | 01:09 AM
ChrisB's Avatar
It's going to depend a ton on your setup - heads, motors - but especially your turbo, boost levels, exhaust (backpressure levels before and after the turbo), etc.
Setting up a cam on a turbo is completely different from setting it up for most other applications (high performance). Your best bet would be to talk to somebody with experience doing it. Kyle (HouseOfSpeed) - the poster above - could probably help you out, and if you want to handle it yourself you might give terry williams at Cam Motion a call.
Chris
