turbo lag??
as for the turbo lag problem, i guess this is what some people were talking about when they said the T-76 was too big for a stock motor. i bet part of your problem is in the running really rich down low. so in whole, programming has an affect on the performance of the turbo's. get that taken care of and see how it reacts then.
Chris
Lag in traffic, squeeze/punch it and how long does it take to make real boost....
Brake torque it at the line, how much boost can you get at zero MPH and how fast does it rise...
So the questions are these:
Which scenario?
A4/M6
Torque converter?? (A4)
Lean-ness helps, but you need to make power/heat to make spool; you need some fuel to make that heat/power.
Timing retard helps spool but kills torque so there is a balance to this.
A T76 is a BIG turbo by any measure, is it ball bearing?
TB
