help me pick another cam
Old Sep 24, 2005 | 01:23 PM
  #41
MIGHTYMOUSE's Avatar
anybody got graphs and stuff of the lingenfelter or the same type cams?
ed, what do you know about the cam in the kordis vette?
Old Sep 24, 2005 | 01:40 PM
  #42
69firebird's Avatar
I know im not the Ed you were talking about but I told ya id get you those numbers.
here they are, Specd by Eric at HPE, and he consulted with some turbo guru in Chicago he said.
228/228 588/588 116
ed
Old Sep 24, 2005 | 10:34 PM
  #43
V8_DSM_V8again's Avatar
I'd check a custom comp out. They have some custom profiles that change the ramp rates below .050 and are conservative with lift since alot is'nt needed and less lift alows for more aggressive ramp rates... Even with a hydralic roller..
http://www.hotrod.com/techarticles/e...rb/index3.html
A turbo engine doesn't require a big cam to make power. The Bennett-designed, Comp Cams-ground hydraulic roller gets the job done and requires little maintenance. It pulls nearly 15 inches of vacuum at idle--good enough to run power brakes. Stock-style lifters, dog-bones, and spiders work fine, too. A big solid roller would raise power but decrease reliability on the street. With 0.550-inch lift and 236 degrees of duration at 0.050, the seemingly single-pattern profile actually has different intake/exhaust opening rates carefully tailored to a turbo motor's characteristics..
Also ask jose about the 230/230 custom comp they had made..
Old Sep 24, 2005 | 11:24 PM
  #44
Rpm2800's Avatar
Is this something we would have to call him about . If not Paging Jose,............................................. .................................................. ................. Come in Jose.
Old Sep 25, 2005 | 03:13 PM
  #45
jay's99transam's Avatar
Originally Posted by Rpm2800
Im no expert , but the problem with people talking about turbo cams is that that the exhaust runs through the turbo . That causes back pressure issues to come into play. With a belt driven supercharger you usually have a larger ex durtation. It's basically seems that it's more simple than a turbo cam and more matter of how much split and lsa, although valve events come into play with any setup whether it be turbo , NA , nitours or supercharger. Belt driven superchargers cams usually have more off a general agreement as being exhaust biased. It's usally how much of a split... will it be 220 in 224 ex or 220in 230ex. Still, though valve events, Rpm , head flow, etc matter but........... it's usually agreed that more exhaust is needed. Although I I don't know if you can pick the best cam for any combo without knowing the combo and what the owner wants.
Turbo engines have to deal with the above events, PLUS more things mainly involving exhaust issues. With a turbo , there is no magic turbo cam for every application. On some setups, a sinle patter may work better , some an intake bias , and some an exhaust bias. I think it's also about valve timing (valve timing events), and not just intake and ex , because like somebody said , there is cases where you can have a cam with larger exhaust that has less overlap that a single pattern or larger intake cam.
If you have an effiecient turbo exhaust housing , header design and , exhaust flow on heads, it will need a different cam than a setup with a log manifold , low flowing ex port, and a small or non effieceint ex housing.
When you see people that say a turbo needs a certain cam without knowing the setup , usally they probably don't know much about turbo cams (NOT that I do) . People that say "a turbo cam always needs a single pattern cam or larger intake", or even certain lsa and don't know the engine and turbo system setup are usally just reapeating what they hear, since that is what most off us see. (Cams like 224 in 224 ex ... or 230in 224ex and usually with lsa in the 113 to 116 range.)
People that just say " a turbo cam has a lager exhaust" are usally thinking that a turbo cam is the same as a supercharger cam. The engine and turbo system seem to matter. I have heard people that know a bit say, that the more effiecinet a turbo system is , the closer to a NA type cam you can use. ie : single pattern or bigger exhaust. Some of the 6, 7 , and maybe 8 second turbo race cars you see have bigger exhaust , but they have huge exhaust housings with not as much back pressure , as well as very efficient headers, and probably good heads.
I think Jose says that if you have an effiecient turbo setupe where the back pressure is less, you can use a single pattern , and if you have a less effiecient or log type setup a reverse split is better . People say it's because of backpressure , reversion , and keeping the intake charger from getting contaminated. But Notice he considers the setup and does not just say reverse, single exhaust bias. Also, turbo cams are probably one of the most controversial and highly dissagreed upon things in motorsports it seems. Often times professionals don't seem to agree. That's not to say that a certain cam will or will not work or a given, motor. It just may not be optimum. You have to also consider .... are you looking for more power, faster spool, bleeding of tourque, more power on pump gas etc. People also have their own ways of thinking . But again i think it's important to consider the setup.
thanks for the awsome post, that does in fact answer a lot of question's, that i've had about cams working with turbos. thanks again for that.
justin
Old Sep 25, 2005 | 04:31 PM
  #46
sr71's Avatar
I am just the opposite of MM. my set-up doesn't make full boost untill 4000 rpms. I'd like to have something that makes power from 4k-7k....and the nastier it sounds, the better I like it!
Old Sep 26, 2005 | 11:27 AM
  #47
longrange4u's Avatar
MM I have my dyno sheet with my T-60 in it and GT-7. I dont have one yet for the 67. My HP and TQ #'s are 431/497
Monster TQ and the lines shoot like rockets... I will scan and post if you want
Old Sep 26, 2005 | 11:28 AM
  #48
1CAMWNDR's Avatar
How about a 226°/220° .581"/.568" 115° LSA +2° (113° IC)?
Old Sep 28, 2005 | 08:18 AM
  #49
Its in Lt4 but comp can make a similar cam in a LS1 style cam..
http://www.forcedinductions.com/TurboSS.htm
Old Sep 28, 2005 | 09:54 AM
  #50
Race-Prep's Avatar
Suspended Sponsor
Hello all, I actually specced this cam for nitrous before I got the turbo installed on my car and yes, it is an STS system but with the GT76/.80AR turbo. The cam spooled the turbo to full boost (only 6 psi for now) by 3000 RPM on a stock engine with this cam 224/232@.050" with .600/.600 lift on a 114 LSA. The car put down 454WHP and 420ish torque. I was very pleased with the performance of the car as the engine is totally stock save for a pulley. All this is through a Moser 12 bolt with 4.11 gears so it did real well considering. I think what is going on here is the fact that modern turbos are so well designed compared to a few years ago that there is very little exhaust restriction comparetively speaking. The goal with this cam was originally to get the largest grind possible to pass emissions in CA so I specd. it with REALLY fast ramps, in fact they are a Ford 5.0L racing lobe from Comp....(hey it was the quickest ramp I could get). But I think because the ramps are so quick there is actually VERY little overlap in the low lift ranges and therefore allow longer exhaust duration to work well without promoting reversion. We will find out if it works good on a bigger engine with more than 18psi very soon as the new engine is almost done and I will be letting you all know how it goes!
-Bryan
Old Sep 28, 2005 | 10:03 AM
  #51
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
No need for a big cam guys. They sound good but don't make a huge difference in power unless you simply have to rev the engine extremely high.
Bryan, one question, if the turbo spooled by 3000 rpms, why is the torque so low?? The torque being lower then your HP is indicative of a slow spooling setup due to a big turbo. Unless your torque is dropping off after the intial spool up.
  #52
-Bryan
Comp can work some serious bumpstick magic.. I think he should get a custom comp specd for the turbo....
I know I'll be swinging a custom comp in the 236/236 114lsa range with some special ramp rate tricks...
Old Sep 28, 2005 | 07:34 PM
  #53
Race-Prep's Avatar
Suspended Sponsor
Well, I see what you are saying but my peak torque did not hit at the onslaught of max boost it happened more around 4-4400 RPM so it was not that low so as to create huge cylinder pressure like you are hinting at. I know what you are talking about, just like a nitrous car with the initial hit, the lower you hit it the more torque it makes until POP! LOL
-Bryan
Old Nov 3, 2005 | 08:25 PM
  #54
Mr_president's Avatar
how much more power does the zo6 cam loose compared to theese other custom cams?? or how much more power from a custom cam?
Old Nov 3, 2005 | 11:04 PM
  #55
Frost's Avatar
There is at least one guy on here going 9s with a Z06 cam and FI setup.... still think you need more?
Old Nov 7, 2005 | 11:29 AM
  #56
TeeKay's Avatar
Originally Posted by Full Throttle
A stock cam for a grand national is 107 l/s tight lobe center works better with turbos on small duration cams. Remember we are looking at overlap and a cam that is say 204 @ .050 on a 108 might have less overlap than a 230 duration cam on a 114. Look at event timing and make sure the exhaust does not open too early. The Z06 cam needs to be wide because of the big split. That big turbine wheel in the 88 will also like about 4 extra degres on the exhaust side I would suggest a 224/228 112 is the tighest I would go with that duration. 114 is the most. Using an X-ER lobe on the intake to open the valve fast and a regular lobe on the exhaust to open it slow works good too. Getting the intake open as fast you can is a benifit but we don't want to open the exhaust as fast. PM or e-mail me some head numbers and rocker ratio and I will be happy to work up my opinion and give you the lobe numbers to work with.
Mike
FWIW, when I had my 9.7:1 383 built last year, I asked More Performance for a cam. I have ported heads that flow about 300 cfm @.600 and springs that are good for .650 lift. I told them I would be boosting in the 8-10 pound range max and 6500 redline. Here's the grind they spec'd for me from Comp Cams: 224/228 - .581/.587 - 114° straight up. They said it would be a good all around cam for N/A and boost. Of course that DOES mean it's not optimum for everything, just streetable power both ways.
GL
Old Nov 7, 2005 | 11:44 AM
  #57
ddnspider's Avatar
ive got a GT2-3 cam in my NA car now.i could post the graph if youd like.im only making like 350rwhp with cam only and exhaust on a N20 tune but itd give you an idea of what it looks like,it pulls pretty hard above 3k and screems above 6k...i pulled it to like 6600 on the graph...its good enough to take a Z06 and sound stock while doing it.let me know if you want me to post it.
Old Nov 7, 2005 | 07:04 PM
  #58
SuperZ's Avatar
I went with a scoggin dickey comp cam.Its 220/224 551/551 114.I like it alot so far and is very drivable.
Old Nov 8, 2005 | 12:42 PM
  #59
02BlueFirehawk's Avatar
If your pipes flow good, 230/230 .550/.550 on a 112-114
Old Nov 8, 2005 | 12:56 PM
  #60
ddnspider's Avatar
do you see what cam he has now?he almost has a cam like that currently.he wants something closer to stock that has better drivability and low speed cruisin.
