help me pick another cam
Old Sep 22, 2005 | 07:08 PM
MIGHTYMOUSE's Avatar
Default help me pick another cam
considering pulling out the 236/231, .601/.594, 115*
i don't see that i gained anything from it on the track or dyno. i have only seen drawbacks like low speed driveability and mileage
my 9 sec. pass was with my stock 98 cam. i think i still have that around somewhere but i'm kinda afraid to take that big of a step back.
i know that lingenfelter comes up with some really trick cams for the turbo stuff.. something in that 'style' sounds up my alley.
toss up some idears.. also if you wanna give an offer on my current cam
here is what i need the cam to work with
pte88, 6 speed, 366ci, cleaned up all pro heads, i will need to wind it out around 6500 to get through the traps and i don't want the cam to kill peak hp...but if it kills torque well i wouldn't mind that at all as long as it was in trade for horsepower.
thanks.
Old Sep 22, 2005 | 07:29 PM
69firebird's Avatar
hmm,
Im assuming you've already consulted W2W?
Eric at HPE picked mine out, I have the specs at home, however my motor is a 347
Any word on your short block yet? Can you have W2W post up the pics ?
if you want those specs let me know Ill get em for ya
ed
Old Sep 22, 2005 | 07:35 PM
i told kurt i'm looking for a diff. cam.. ive told him that before... the above one was done thru cammotion. i'm sure it 'works' but its just too big and nasty for me when it doesnt need to be.
i dont think wheel has received the motor yet.
you dunno what a broke piston looks like?
Old Sep 22, 2005 | 07:49 PM
69firebird's Avatar
I know what a broke piston looks like, i just dont know what your borken piston looks like
Old Sep 22, 2005 | 07:50 PM
Got Me SOM's Avatar
z06 cam, keep the driveablitly nice
Old Sep 22, 2005 | 07:52 PM
Cmarsh93z's Avatar
Whats your silly obsession with seeing his piston?? Watch out! You have only asked like 10 times in several threads..
Old Sep 22, 2005 | 07:54 PM
69firebird's Avatar
about as gay as the way you used to tune cars
Old Sep 22, 2005 | 08:12 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
David, you don't need more then a 220 to 224 duration to reach 6500. Also thats a heck of a lift for a turbo motor, and no need for it. The 88 will push the air through whether its a stock cam or big cam. It may change the hp output per lbs of boost, but it will still be within 1-2psi. Plus you will gain driveability and some mileage back.
Old Sep 22, 2005 | 08:23 PM
W8N2SQZ's Avatar
Dave I spoke with W2W a few months back about some All Pro's and a cam choice. They told me that one of the cams they like is the 385 horse Z06 cam. I am sure you have spoken with them about cams. Just food for thought.
Glenn
Old Sep 22, 2005 | 08:30 PM
can you guys gimmie some specs on these zo6 cams? doesn't cablebandit have a zo6 cam?
Old Sep 22, 2005 | 08:31 PM
JMBLOWNWS6's Avatar
Im not a big baller. But my cam is 224/230 .581/.591 114 +4 Jeff (Inspector12) got it for me for a great deal new from comp.
Old Sep 23, 2005 | 12:08 AM
jay's99transam's Avatar
here are some specs. for ya dave.
----------- Dur in. Dur ex. Lift in. Lift ex. LSA
01 zo6 ---- 204 --- 211 ---525 ---525 ---116
02 zo6 ---- 204 --- 218 ---551 ---541 ---117.5
Justin
Old Sep 23, 2005 | 12:22 AM
V8_DSM_V8again's Avatar
I am looking at a custom ground comp in the 236/236 114-LSA range... Its a turbospec lobe profile probably like the 230/230 114lsa Forced inductions has in their project SS..
I am also looking at all pros
Old Sep 23, 2005 | 05:38 AM
smokinHawk's Avatar
when you ran that nine on the stock cam was it stock cubes as well? cant remember.
you probably need just to bump down the duration and lift.
not sure how your car drives but you should use that as a reference. (im not sure how that cam reacts with your 370 cubes.
maybe a 228/224-115 with a .581 lift.
not sure how tame that will be.
Old Sep 23, 2005 | 05:49 AM
cablebandit's Avatar
David I had a zo6 cam a long time ago. Now i have a 215/215 .523 114
I'd like to see someone try something along the lines of a 112-113 lsa....I would have but I was afraid it would lope. I had a 231/226 115 cam before this one....I basically got what you said, less mileage and low rpm torque.
Old Sep 23, 2005 | 06:52 AM
thanks for those zo6 cam specs
jerry, something i see in common with the zo6 cam and all of lpe's turbo cams is BIG lobe sep, 117-120* i dunno how you can go against what they do and think 112 is the right direction to go... but im not smaat mayun.
ya my nine was stock cam, stock cid, 19psi & gt80-r turbo
Old Sep 23, 2005 | 07:44 AM
xssive's Avatar
The guys over at Speed Inc are big into the low lsa turbo cams. Ill personally be going with a 236/232 on 112 in my new 370ci
Old Sep 23, 2005 | 08:06 AM
stevieturbo's Avatar
So having huge amounts of lift, arent really of any benefit with a blower ??
How much is enough ?? I'd have thought the only downside to having a lot of lift, is valvetrain reliability ?
Old Sep 23, 2005 | 09:11 AM
Full Throttle's Avatar
A stock cam for a grand national is 107 l/s tight lobe center works better with turbos on small duration cams. Remember we are looking at overlap and a cam that is say 204 @ .050 on a 108 might have less overlap than a 230 duration cam on a 114. Look at event timing and make sure the exhaust does not open too early. The Z06 cam needs to be wide because of the big split. That big turbine wheel in the 88 will also like about 4 extra degres on the exhaust side I would suggest a 224/228 112 is the tighest I would go with that duration. 114 is the most. Using an X-ER lobe on the intake to open the valve fast and a regular lobe on the exhaust to open it slow works good too. Getting the intake open as fast you can is a benifit but we don't want to open the exhaust as fast. PM or e-mail me some head numbers and rocker ratio and I will be happy to work up my opinion and give you the lobe numbers to work with.
Mike
Old Sep 23, 2005 | 10:11 AM
lpe reccomends their gt-7 cam
http://www.lingenfelter.com/store/ls1-gt7.html
