Maft or maf causing misfires
Old Dec 22, 2001 | 04:31 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default Maft or maf causing misfires
Ok here it is Ever since I got these #42lb injectors its missing sometime(was alot worse). I ported the maft and it got worse. I then richen it up and it stoped alittle but ist still there. I have to atap I think. But it throws a code and you can feel the hole engine change so it must be in some kind of reduced power mod or something. I'm thinking maybe a maf code low or high code or malfuntion. time to put the comp on the charger
Old Dec 24, 2001 | 11:47 AM
JAS BLK 98 TA A4's Avatar
Default Re: Maft or maf causing misfires
Todd, do you have programming for the 42's? Why are you richening it up with a MAFT?
Old Dec 24, 2001 | 11:53 AM
Cool28's Avatar
nah no programming for the #42. Waiting for ls1edit <img src="images/icons/rolleyes.gif" border="0"> . I had to richen it up even if it rich cause it was causing it to misfire drving down the road. I know doesnt sound right. it helped the misfiring though. I dont know lol.
Old Dec 24, 2001 | 01:34 PM
Ragtop 99's Avatar
What are your LTRIMs? 42lbs is a lot of injector to compensate for with just a MAFT.
Old Dec 24, 2001 | 01:35 PM
Blackbird's Avatar
I still can't believe you have not blown that car up yet <img src="graemlins/gr_jest.gif" border="0" alt="[jester]" />
Good luck to ya.
So, how are you correcting for the 42lber's? Ported metter + maxed out lean maft?
If you still have an 4L60E tranny drop me an email.
