Potential cam for project Evil Twin
This cam will work OK for you Harlan but there are others that may be more suited as you are getting fairly agressive with the boost, shoot me an e-mail if you need any info.
Its accepted that it is more efficient to open the exhaust valve a little early. The pressure difference between the header/exhaust port (less pressure) and combustion chamber (higher pressure) will pull the exhaust out instead of the piston have to pump it out.
Perhaps since the intake valve is favored more combustion pressure will occur hence more of a pressure differential before/after the valve. Leading to better scavenging?
Nah, I don't think that holds merit.
