Powerdyne on a 408??
Old Sep 23, 2005 | 09:24 AM
necrocannibal's Avatar
Default Powerdyne on a 408??
Ok my 408 is running 11 : 1 compression and Im spraying it at the moment. Could I safely run a Powerdyne on it at around 6-7 psi?? If so how much power would it make if I make between 460-480 right now on motor?
Old Sep 23, 2005 | 10:22 AM
Blackbird's Avatar
it might make 2psi if your lucky.
Old Sep 23, 2005 | 10:41 AM
Bryan @ Speed Inc.'s Avatar
11:1 compression + boost = motor go boom. keep sprayin it... if you want to go the FI route, then rebuild the motor with lower compression pistons and/or big chamber heads.
Old Sep 23, 2005 | 02:22 PM
Ok so say I bumped the compression down with larger combustion chamber heads, how much would I be looking to pick up with it?? I know alot of people dont like them but they are cheap used.
Old Sep 23, 2005 | 06:42 PM
Slowhawk's Avatar
LS1Tech Sponsor
I'm thinking 1psi at redline The blower is in no way big enough to drive a 408.
Old Sep 23, 2005 | 06:44 PM
Ahhh ok, thanks for edumacatin a poor ole nitrous boy.
Old Sep 23, 2005 | 07:14 PM
BubaGumpShrimp's Avatar
yea small supercharger, hardly big enough to push 6psi on a stock ls1.
