Vortech pulley change
Old Sep 23, 2005 | 11:22 AM
Rexx's Avatar
Question Vortech pulley change
I am thinking about going from the stock pulley on my vortech supercharger 3.12 to a 2.95 and I was wondering what I could expect from this change. I expect that it would be 1-2 lbs of boost but any idea as to the hp/tq increases that it would show. I did a search but I could not find anything that that had a before and after for numbers. Thanks in advance for the help
Old Sep 23, 2005 | 12:50 PM
Got Me SOM's Avatar
you see about a 2 lb increase and boost will come in sooner.
i went from 448 to 476 when i did it and i have an a4.
Old Sep 23, 2005 | 04:00 PM
DeltaT's Avatar
Watch for more slip with the smaller pulley...
Jim
Old Sep 23, 2005 | 04:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd think 1.5-2.0 psi.
Old Sep 23, 2005 | 04:33 PM
Rexx's Avatar
Thanks for the replies. Hopefully I can get one in and tuned before the last drag racing even here. Damn weather in Canada does not allow for a long drag racing season. The cold air should be nice though.
Old Sep 23, 2005 | 04:47 PM
Got Me SOM's Avatar
Jim
Vortech's don't have that problem
Old Sep 23, 2005 | 05:05 PM
2001WS6Vert's Avatar
Go with the 2.75. You'll end up there eventually anyway.
Old Sep 23, 2005 | 08:25 PM
Got Me SOM's Avatar
i'll be ordering mine next week, then gotta get a BAP and throw in bigger injectors then she what she does.
Old Sep 23, 2005 | 09:01 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah the 2.75 will be a better choice IMO.
Old Sep 23, 2005 | 11:26 PM
DeltaT's Avatar
You guys with the 2.75" pullies - what is the max rpm you run the blower to? What size crank pullies are you running, 6.66 or 6.0? Also, what's the redline you use on your motors? 6-rib or 8?
Just trying to get a sense of the V-9. I know it has a 65K redline vs. my V-2 S-trim's 50K.
Thanks,
Jim
Old Sep 24, 2005 | 06:27 AM
Got Me SOM's Avatar
I am changing to the 2.75 pulley probably next week, i plan on shifting at 6500 even though I'm still making power past that. I use the crank pulley that comes with the kit, for some reason I can't think of the size but i can check on that. 8 rib belts.
Inspector 12, i got a helluva deal on some 50 lber's i cannot wait to redyno this thing. Its probably going in next week or the week after.
Then I seriously gotta work on suspension, tire spin = no fun
