gear ratio for 9"
Old Jan 2, 2002 | 10:45 PM
2bseen's Avatar
11 Second Truck Club
Default gear ratio for 9"
what gear ratio do I need with 6-speed and vortech and does anybody make studs bolts for block to heads for ls1?
Old Jan 3, 2002 | 01:00 AM
Terry Burger's Avatar
Default Re: gear ratio for 9"
I'd go with the 3.89 gear set. With a blower its important to get the RPMS up quickly and get in (and stay in) boost. With a 6600rpm rev limit you should have no prob going 125+mph.
MMS sells head studs and bolts for our cars, as well as special head gaskets.
Old Jan 3, 2002 | 06:42 AM
Nickn20's Avatar
what kinda tires you plan on running 26s? 28s? look at a gear calculator to help you decide.
Old Jan 3, 2002 | 08:25 AM
2bseen's Avatar
tires for the track are 26-9.5 hoosiers. thanks for replys
Old Jan 4, 2002 | 11:13 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If that was my car, I'd of course run 28" tall tires.
I'd run at least a 3.70 gear. I'd consider a 3.90 but it depends on how hardcore the setup will be.
I run 4.10's in my A4. It's a lot of gear.
Old Jan 4, 2002 | 05:59 PM
steve's Avatar
try to stick with the 28x10.5 tire, it would hold
up to the power.
tose 26 inchers are gonna be hard to hook on or be real inconsistant.
steve frank
