How much boost can the 6.0
Old Sep 24, 2005 | 11:50 PM
AntiVenom06's Avatar
Default How much boost can the 6.0
Hold, with stock internals?
It will be intercooled
Old Sep 25, 2005 | 12:53 AM
NOSjohn's Avatar
Restricted User
I recall Jim spraying his with 12 on a very good tune. He worked his way up. If you're speaking of the LQ4 motor, it is lower compression so it can initially handle more.
Old Sep 25, 2005 | 01:33 AM
Wnts2Go10O's Avatar
but since the boost is compensating for compression wont the lq9 make more power?
Old Sep 25, 2005 | 01:48 AM
NA$TY-TA's Avatar
Id say dont go over 8-9 psi i fu want it to last a while......... but hey its your $$$$$
Kyle
Old Sep 25, 2005 | 08:37 AM
EPP's Avatar
EPP
8 to 10 pounds of boost with stock internals, with air/fuel in the 11.5 to 11.7/1 range. The #7 piston's ringland is the one you have to worry about on the LS. Bob
Old Sep 25, 2005 | 08:45 AM
C6.Z51's Avatar
I would keep it under 10. If you bought a set of heads you could probably run a little more boost due to the increased flow.
Old Sep 29, 2005 | 11:03 AM
nascar75's Avatar
how much boost do you tink it can handle with forged internals.
Old Sep 29, 2005 | 11:35 AM
NOSjohn's Avatar
Restricted User
As much as you can throw at it without getting KR.
Old Sep 29, 2005 | 02:09 PM
Zombie's Avatar
Finally, a voice of reason. Power doesn't break things usually, detonation does though.
