408 compression
Old Sep 25, 2005 | 08:00 PM
CarolinaWS6's Avatar
Default 408 compression
ok i have a 408 iron block and im building it for boost/turbo cartek says to get the compression around 9:2:1 should i go lower than that?
Old Sep 25, 2005 | 09:03 PM
nitrorocket's Avatar
Go lower, why not? Go with 8:1 if you can. There is no such thing as turbo lag with a good setup if thats what you want to know.
Old Sep 25, 2005 | 09:07 PM
mahhddgtp's Avatar
Depends on how much boost you want to be able to run. It sounds like it's going to be a track/speed setup... You could actually go a half-point to a full point lower if you really wanna put through some boost.. Meth always helps.
If I had money for a setup, I'd go for the street compression... 9:1 or so. You have a good bit of power down-low.
Old Sep 25, 2005 | 09:37 PM
its going to be a street/strip car
Old Sep 25, 2005 | 10:47 PM
mahhddgtp's Avatar
Street/Strip?
I think 8.5 to 9.2 would be great.. Even if you went as low as 8.1, you wouldn't exactly have a dog low-end, since you'll have so many cubes.
Old Sep 26, 2005 | 12:13 AM
sagres's Avatar
I went 8.7 compression with -32 cc pistons in my 408.
Old Sep 26, 2005 | 10:20 AM
PurEvl's Avatar
8:5:1 here...Na numbers in sig
Old Sep 26, 2005 | 02:58 PM
Blown408's Avatar
Can you give some more information on your engine? You can PM me if you wish, but I would really like to know more. You N/A numbers look awesome for such a low compression.
Thanks in advance!
 Michael S. Palmer
Old Sep 26, 2005 | 04:38 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Go 8.5.....no reason for any higher. Gives you plenty of room to play with boost.
Old Sep 26, 2005 | 06:43 PM
2000 Tran Zam's Avatar
ya, im going with 8.5 in my 408 with the gt55 turbo. what size turbo do you plan on running?
Old Sep 26, 2005 | 06:47 PM
NA$TY-TA's Avatar
Stock PCM?? What YR computer?? Id go lower then 9:1 also.....
Kyle
Old Sep 27, 2005 | 08:31 AM
PurEvl's Avatar
Thanks in advance!
call cmotorsports and ask them to build you there outlaw 408
Old Sep 27, 2005 | 12:04 PM
Blown408's Avatar
I am in the process of having one built right now, but I was wondering how much mine differed from yours. What heads, intake, cam and exhaust are you running?
Old Sep 27, 2005 | 01:06 PM
PurEvl's Avatar
afr 225 76cc, small 220ish cam, 18" bullet custom exhaust
Old Sep 27, 2005 | 01:52 PM
Blown408's Avatar
How much power are you planning on making with how much boost? What headers/intake are you running now?
Thanks.
Old Sep 27, 2005 | 01:57 PM
PurEvl's Avatar
stock ls6 intake, phamspeed headers...planning 800ish on pump
Old Sep 27, 2005 | 02:01 PM
Blown408's Avatar
Thanks a lot! Keep us posted.
