Cooler Air == Running More Lean?
- Dug
<strong>.900 is still pretty lean.
I'd shoot for .930</strong><hr></blockquote>
You can't always assume the same A/F vs O2 for everybody. Sensors vary, location/temperature effects the numbers.
I run 885mv to 900mV, and that's wideband tuned for 12.2 to 11.8 A/F
Did your boost change at all w/ the lower temps?? I often see as much a 1 psi increase on a cold day. How much injector do you have? The denser air may be pushing them a little too hard <img src="gr_sad.gif" border="0">
[ February 13, 2002: Message edited by: y2khawk ]</p>
- Dug
