Vortech question?
Old Feb 15, 2002 | 01:22 PM
SSman's Avatar
Default Vortech question?
I was wondering what kind of horses i could expect from my setup:
382 stroker
stage 2 heads
570/578 lift; 230/236 ; 114 lobe sep
vortech w/after cooler
42# injectors,t-rex inline; and 255 intank
100 shot wet TNT
mac header w/custom x-pipe
m6
3.73's
thanks
Old Feb 15, 2002 | 01:24 PM
SSman's Avatar
Default Re: Vortech question?
The boost is at 10 psi <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Feb 15, 2002 | 01:39 PM
1FastPewterZ's Avatar
alot
Old Feb 15, 2002 | 02:26 PM
smokinHawk's Avatar
100 shot with #10 ike. whats your compression ratio?
Do you have this setup or thinking of getting it?
Not to many run a shot with boost. You've got *****!
Old Feb 15, 2002 | 03:09 PM
Blackbird's Avatar
I dont think you have enough fuel system for that.
I may be totally wrong but it seems to me you have just enough to support the motor and blower.
If you do have enough fuel and it doesn't explode I would guess around 650+hp 700+tq
Old Feb 15, 2002 | 04:00 PM
SSman's Avatar
I have this setup already; it should be finished in a couple of days. There are about 4-5 guys here in San Antonio who are running the same setup without the stroker. The purple z is running wiseco pistons,ported heads,tnt 100 shot;and 10 psi....10.29 @ 139.8. The same thing goes for another trans am in Eagle Pass but with no ported heads....10.30's @ 136..None of these cars has ever had a problem.. They put on about 500 miles a week on these cars.
Old Feb 15, 2002 | 04:11 PM
Blackbird's Avatar
wowzers! that is moving. well I did say I could be wrong. Just make sure A/F looks good on the dyno/wideband and not assume it will be safe is all I can say.
keep us posted.
