Those of you using the 8 rib setup.
Old Sep 26, 2005 | 10:45 PM
nvmy2000ss's Avatar
Default Those of you using the 8 rib setup.
I have a question. I ordered the ATI dampner 10% underdriven, when I ordered it I was told it would work with the 8 rib setup for the procharger. I recieved it today and there is no way that the crank pulley will fit in the dampner. Is there another pulley that sdce sells sricktly for the ATI dampner. If this is the case that sucks cause I just spent 600 on the kit.
thanks
Brian
Old Sep 26, 2005 | 10:53 PM
618HAWK's Avatar
Not sure what you have but the 8 rib and ATi superdampner, setup consists of the dampner assy which bolts together, to the main hub unit. Than the 8 rib drive pulley for the head unit bolts directly to the front of the super dampner.
Not sure what type of crank pulley you are refering to.
Old Sep 26, 2005 | 11:39 PM
nvmy2000ss's Avatar
Bolts into the stock crank pulley fine, it indexes into it. It sounds like there is a diffrent pulley that hooks up to the ATI dampner for the 8 rib setup. I will try to post pics.
Old Sep 27, 2005 | 12:17 AM
HUGGER ORANGE SS's Avatar
I believe you need to tell ATI which Crank Pulley your running as they have a 8 rib pulley for both the stock crank, and one for the ATI Dampner...
Good Luck.
Clint
Old Sep 27, 2005 | 06:30 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=455
The above link is to the 10% underdrive model.
http://www.exoticperformanceplus.com....html?item=457
The one above is standard diameter. Bob
