Cast iron or Aluminum?
Old Mar 21, 2002 | 07:23 AM
SSman's Avatar
Default Re: Cast iron or Aluminum?
Jason thought I shoul go with a Speed pro setup w/#84 injectors.?
Old Mar 21, 2002 | 04:23 PM
gospdrcr's Avatar
I have seen a broken block. But it was from a piston. The piston ring was wrapped around the camshaft and the block around cylinder #5 was broken on the water jacket all the way down the cylinder. From nitrous <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Mar 23, 2002 | 10:08 AM
1dirtyZ's Avatar
#84!!! uhgggg!!! can't breath!!!
what are these ?? shower heads!!!!
seriuosly, the aluminum block has a problem with it being able to maintain it's shape and avoid warping. i'm saying this from my own experience, i had ~60k miles of hard driving with no blower on my engine and when i tore into it , i found that some spots on some piston walls that still had the crosshatch, and other spots ( some on the same pistons) had severe wear .
the only scenario i could come up with is the block dforming under stress, and i could only emagine how long an aluminum block would last it it had a big blower , or worse yet having material removed for bigger liners.
Old Mar 23, 2002 | 10:19 AM
y2khawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by SStrokedTNTLS1:
<strong>Jason thought I shoul go with a Speed pro setup w/#84 injectors.?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Good <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I'm going with 96's myself <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
My bores showed no signs of uneven wear with some pretty hard abuse.
One thing to watch in a stock motor is the wrist pins. With a press fit in the rod, once you start to bend them w/ severe cylinder pressures bad things start to happen. pistons get cocked funny and the bores take the beating.
I have no plans to go iron.
Old Mar 23, 2002 | 03:32 PM
Black LS1 T/A's Avatar
Moderator
1dirtyZ, from what Jason at GWP says, you are right.
He said when you make just so much HP with the aluminum block, things start moving around too much in there... and not the way you like! <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" />
Old Mar 24, 2002 | 12:56 AM
SSman's Avatar
What kind of computer will you use w/the 96's.It is my understanding that you cannot go with anything bigger than 50's with a ls1 comp. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
