Cast iron or Aluminum?
but i would have to say the iron block that is why you cannot go with alot of bost on stock ls1's
The issues with boost levels are not block related at this point.
I'm still using an aluminum block for my build up, stock cubes too.
All numbers to date are stock motor, valve covers to oil pan
<strong>Going with a supercharged 422. Should I have them use a cast iron or aluminum block? I will be running about 10-12 psi through a D-1.
thanks</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">sENSE YOUR SPENDING THAT KIND OF MONEY ON YOUR TOY THEN GO WITH THE ALUMINUM BLOCK.Less weight and it should be plenty strong with the beefed up internals.
<strong>Do you really want to add the weight of an iron block??
All numbers to date are stock motor, valve covers to oil pan</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">what if youre tryin to see 7-800 rwhp tho
mine is not goin in an f-bod tho. <strong>what if youre tryin to see 7-800 rwhp tho
mine is not goin in an f-bod tho.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> a wimpy 348 cu. in. and 8.7:1 CR.
Incon Kit at 10#
single intank Walbro 255 l/hr
SVO 42 injectors
Returning fuel rail w/ manifold ref. regulator
Tuning
To hold the driveline together:
DTS 12 bolt
3" chromoly drive shaft
RAM clutch
Do what you want to do, but I personally don't see a reason (yet) to add another 60 to 70 lbs to the front of the car. Haven't seen any broken blocks yet, and any head sealing issues are a function of the head deck thickness right now. Not block strenght as far as i can tell
Time will tell i guess, as there are a bunch of big power/big boost cars starting to pop up
I think Nick knows. The gasket was pretty good already, but is even better within the last month now.
Head Studs should be a pre-req.
Ask about this one:
NEW HP MLS 1.45mm/.057" High Performance Ringed Boost Gasket
<small>[ March 19, 2002, 10:49 AM: Message edited by: MelloYellow ]</small>
That's just a feeling, though.
I'm sure the guys doing it have good reasons...
thatnks
<strong>Is it just the structural integrity of the iron block that makes it better over the Aluminum block, or other things... educate me, please. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">While the aluminum block is very strong, I've heard that it just does not have the internal strength to support decent or large amounts of boost from blowers like the iron block can. Just from my personal experience, the LT1 seems to hold up better to boost than the LS1 does, assuming both motors are built up properly with the right compression ratio to handle big boost levels. Stock for stock, I don't think it would really matter since you'd be taking a risk either way. Some motors will just last longer than others, even on more boost(as strange as that seems). I could be wrong on some of this, but its just what I've heard. Now as far as specifics, I'll leave that to someone else. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Mike
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Black LS1 T/A:
Mike</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Name one guy with a broken aluminum block, from too much HP.
Also, didn't valvegod stop selling engines with spun bearings because often times the block was damaged and could'nt be repaired? To me that is a sign once the engine hiccups, aluminum blocks are more vulnerable.
