Aux Pump vs. In-Tank?
Old Mar 19, 2002 | 10:53 AM
MelloYellow's Avatar
Default Aux Pump vs. In-Tank?
What are the adv/disadvantages of each setup?
Install time for each?
Would the Aux setup be more failsafe?
The Walbro 340 & 42# seems a popular setup using stock lines. Do you need to modify the stock Fuel Pressure Regulator?
<small>[ March 19, 2002, 11:07 AM: Message edited by: MelloYellow ]</small>
Old Mar 19, 2002 | 11:43 AM
smokinHawk's Avatar
Default Re: Aux Pump vs. In-Tank?
I think the intank would be more fail safe, an intanke would go alot further., Inline is just a booster.
the 340 and 42# would be a good choice for 500rwh or maybe even more.
Old Mar 19, 2002 | 03:02 PM
Thx!
Some of the aux boost pumps are rated pretty hi tho, like the top end Aeromotive, right?
How much install time for a Walbro 340?
Can y'all explain the fuel pressure regulator purpose, stock capabilities and what to use/why to upgrade the FPR?
Old Mar 19, 2002 | 04:49 PM
red ws6 99's Avatar
You have a Corvette correct, if so I am not sure whats required to change out the pump. The fuel pressure regulator should be boost referenced so that as boost increases you get an equal increase in fuel pressure. That way the delta between manifold pressure and fuel pressure stays constant. The stock is not adjustable.
Gary
Old Mar 19, 2002 | 09:34 PM
Thx, ya C5. They phased out the adjustables in '98 I believe. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Ya, not sure how much time req'd to swap out the pump.
What kind of boost referenced regulators are people using with the Walbro 340's? Anyone have a price/part#/source?
What happens if you use the stock one? Pressure will fall under boost even with the 340?
TIA!
Old Mar 20, 2002 | 12:11 AM
red ws6 99's Avatar
Intake would be better and add a boost referenced fuel pressure regulator either at the rails or back at the stock return point. You can cap the stock regulator in the tank or some people have left it in that way you will at least maintain 58 psi if the external craps out.
Gary
Old Mar 20, 2002 | 01:32 PM
Awesome, thx!
Anyone have the Aeromotive Regulator price, p/n, source?
Old Mar 20, 2002 | 04:41 PM
red ws6 99's Avatar
The aeromotive regulator part number is AEI-13101 in the summit catalog and is $129.
Gary
Old Mar 20, 2002 | 10:11 PM
Thx!!
Old Mar 21, 2002 | 12:32 AM
red ws6 99's Avatar
The pressure may not fall (said might not) with the stock regulator but the delta across injectors will fall, which means you are getting less fuel in. Most people are using the the big aeromotive regulator, the one that supports like 1000 hp, not sure on the part number. Somebody should remember it. I still have a small regulator that aeromotive makes for the lt1 cars that has been modified with the gm push-on fittings. I would not recommend it because it can be pretty erratic with a base pressure of 58 psi + boost, it was designed for a base pressure of 43 psi +boost. So its not really design for that high of pressure, and actually is referenced of vacuum instead of boost, so that it works a little better with the Incon Setup.
Gary
<small>[ March 20, 2002, 12:32 PM: Message edited by: red ws6 99 ]</small>
