Interest in a Working Scavenge pump GP?
<strong>
I dont think anybody has gone through all the broken pumps to see what the failure mode is.
You're probably right about this.
I do failure analysis of valves and other components at work and on most things its a very simple problem.
A big part of my job is failure analysis of disposable medical devices.
If everyone could post what failures you are having, this would include leaks, not pumping, etc. Also if you guys could remove the two bolts and look inside at the check valve, cam, diaphragm(spelling), seal and see if anything looks damaged. This would greatly help fix the problem.
Gary</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I may take apart mine again, but even if I don't, I remember what it looked like. Do you mean the 4 screws that are readily visible from the outside, or the two screws that are buried in the top, and are used to change the orientation of the inlet and outlet? Nothing has ever looked wrong once the 4 screws were removed. If you really mean the two screws, I don't recall checking these recently, but I think that I may check the tightness on these tonight.
Mine seems to just start leaking from where the plastic top joins the rest of the assy, but this may just be an effect and not a cause.
Are you gentlemen speaking of a dry SUMP oiling system, or a vacuum PUMP?
You're giving mixed signals (to stupid people like me). Please explain.
SC
<strong> I'm on the list for a single turbo Stage II kit from LSIMotorsport, and I don't understand this post.SC</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">the issue is with Incon TT only afaik. most kits have gravity oil return. the Incon turbo oil returns are too low to use a gravity return method, so you need a pump to route the oil back to the pan.
Gary
Gary
