alcohol/water injection
Old May 4, 2002 | 10:03 PM
Mark B's Avatar
Default alcohol/water injection
What alcy/water systems would you recommend for a supercharged motor? I will be buying one soon and would like to know which one you guys recommend. thanks,
Old May 4, 2002 | 10:29 PM
cablebandit's Avatar
Default Re: alcohol/water injection
SMC kit.....look up SMC alcohol injection
Old May 5, 2002 | 12:35 AM
Blackbird's Avatar
Or make your own.
Not hard to do and you can save some cash.
But there are alot of pre-made kits out there that look pretty good.
Just search for alcohol injection on google. You will find at least 5 different kits.
If your not too budget conscious the aquamist setup is sweet. Very compact little kit. I would check to make sure it's ok to run a water/alky mix thru it though.
I made my own with some guidance from the web and a member of the forums and it works beautifully.
