Turbo with Headers
Old May 14, 2002 | 11:56 AM
BEASST99's Avatar
Default Turbo with Headers
Can you run headers with a turbo or would getting headers be a waste of time? I plan on putting on a T-76 turbo.
Old May 14, 2002 | 06:50 PM
EvilTwistedTwins's Avatar
Default Re: Turbo with Headers
Yes you can....matter a fact i wouldnt run anything less then a good well made header <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Old May 14, 2002 | 10:04 PM
WS6underPRESSURE's Avatar
You could make short tube headers work, but long tubes might be a problem because you have to much distance between the head and the turbo, and to much extra exhaust piping.
Old May 15, 2002 | 03:30 PM
Nickn20's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by EvilTwistedTwins:
<strong>Yes you can....matter a fact i wouldnt run anything less then a good well made header <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yes custom made headers, i will agree, he is asking if he should get some mid-lenths, longtubes or shorties, all of them would be a waste.
Old May 16, 2002 | 03:12 PM
Guido's Avatar
You need to get a set of long tube stepped headers with a 4" collector to handle all of that air that you will be adding from the turbo.
<img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old May 16, 2002 | 03:16 PM
MIGHTYMOUSE's Avatar
hey nice avatar, hehe..
on a turbotech kit if you are referring to it (t-76) you can run a passenger shortie header that would bolt to the factory y-pipe such as jba. but it really wont do much for the money.
if you custom make a turbo kit, careful of what type of header you use in the fab, because there is much more exhaust pressure/heat in the pipes on turbo vs. naturally aspriated, and regular headers wont withstand the pressure/heat for long.
Old May 18, 2002 | 03:52 PM
n20junkie's Avatar
i make my own turbo headers, and i also make them for others, on my TT SBC i used flanges from CA Chassis works, and i used industerial 2 in sch 80 pipe, it is about 1/4 inch thick , makes for about a 25 lb header,about par with a cast iron manifold, but it can support a big turbo without bracing and it can take the heat, and it will not conduct heat like a thin tube header, so no wrap is required, stainless is always better but these things can be made for about 500 VS 1000+ for a custom header and they are good for life, oh and the thick tube helps keep flange warp down to a minimum.
Grant J Farmer
