precision 76gts?????
Yes compressor cover A/R's change the flow output, turbine wheel design, and turbine housing size is also a factor.
Jose
Yeah, because they make the COMPRESSOR maps while the turbo is on the car.
If the turbine wheel had anything to do with a compressor map, it would not be called a compressor map. I have never seen any documentation saying that Garrett tests their turbo's to SAE standards and have been told the contrary by a Honeywell engineer. They spin the turbine side of the shaft with an electric motor, not their finger. That way they can control the RPM exactly and give you the nice little map. They don't even have a turbine wheel hooked up while they do it, so how can it have any effect on the map?
Ever seen a Garrett compressor map that made any reference to the turbine side of the turbo? I never have. They do tell you the wheel and compressor housing it is in though.
Here is the schematics of a turbo test stand. SAE J1826....
Turbo test stand
Right click and save as.
Any other questions.... BTW, we have all the documentations for a reason. We are working to do compressor map testing for one of the large turbo companies. Anything else
Jose
I would love to see a big cube 400+ ci LS1 with T3/T4 turbos. It has been done....will make power, but at the sacrifice of huge exhaust backpressure (2.5 to 3:1). Kills power, glowing headers, reversion in cylinders, lifting heads...etc..etc.
Jose
-Bryan
Turbo test stand
Jose
ha ha
good one Jose........................ The small blue dots represent 3500 rpms, the big blue dots represent 6000 rpms. The single green dot was a 346 at 6000 rpms. This represents my current motor. At 14 psi of boost I made 625 rwhp, if you look at the map I should be flowing roughly 66lbs/min. 67lbs/min * 10.5 = 703 HP which seems to be pretty close assuming a 12% drivetrain loss for a M6. 703 * 88% = 619 rwhp. Maps and calcs seem to work pretty good to me.
Each dot is a 5psi incriment upto 20 psi. The maps are used to get you in the ball park. The new wheels extending the maps to the right slightly further, ITS rates my 76 at a hair over 105lbs/min. Graphs assumed a 370 motor.
T76
T80
As you can see on the 76 map it's geting close to the choke line.
-Bryan
I looked at low boost of 8 & 10 psi @ 3500, 5000, and 6500 rpm and plotted them on a T76 compressor map wanting something in the 750-800 chp range. Both showed that at 3500 the data points are in the most efficient (78%) range, at 5000 there is only a small drop to 70+%, but at 6500 its pretty close to the choke at an efficiency below 65%. So I'm thinking that the T76 would support 6000 RPM at 10 psi and make somewhere in the neighborhood of 720-750 hp out of a 383. The most efficient boost level (according to the map) appears to be at about 12 psi and looks like it would make about 800+hp on a 383.
What that says to me is that a T76/383 combination would make a very powerful street/strip setup with only a mild trade-off over 5500-6000 rpm. I would think that a 370 would be close to the same thing since it's only about 3% C.I. difference. And, oh yeah, it would need meth or an IC to get away with it on anything like 93 octane.
How does that fit with what Jose and Nate et. al. are saying?
Jose
What do you mean when you say, higher pressure ratio? Do you mean more and /or cooler oxygen per cfm the unit pumps.
As for the PR. Its a representation of PSI(compressor output) vs Engine consumption. IF the PR ratio does not reach a certain level the compression of air from the compressor wheel starts to loose efficiency. Take a look at the compressor maps posted within this thread. You will see, if the engine consumption is high with relative low boost the turbo will start to blow hot air and reach the choke line. The opposite of that will take you to the surge line (diagonal line on compressor map). Which is the turbo outputs more then the engine can consume at a certain level.
Jose
Pressure ratio = (Boost pressure + Pressure drop from turbo to intake + Pressure drop upstream of the compressor + 14.7)/14.7
Thos 2 corrections can make substantial changes to Pressure ratio. For instance, if you're running 20 psi boost, then:
Pressure ratio = (20 + 14.7)/14.7 = 2.36
However, if you're losing 1 psi upstream of the compressor and 3 psi downstream, then it becomes:
Pressure ratio = (20 + 3 + 1 + 14.7)/14.7 = 2.63
