need help with AEM wideband it is not working
Old Oct 1, 2005 | 11:31 PM
Darren P's Avatar
Default need help with AEM wideband it is not working
I just installed a AEM wideband on my turbo car and it wont work at all
I hooked the red wire to 12Volt swiched and black to the gorund and ran from the same sources to wire the turbo smart boost controller and it works but the wide band does nothing at all
I did not hook other two wires to anything at all
did I do something wrong or what
oh and I checked the fuses and they are fine
Old Oct 1, 2005 | 11:46 PM
Wnts2Go10O's Avatar
those 2 other wires prolly need to be connected to somethin
Old Oct 2, 2005 | 12:12 AM
Darren P's Avatar
one is for dataloging and the other is for a aftermarket engine control
which I dont have either
Old Oct 2, 2005 | 04:27 AM
y2khawk's Avatar
What's it not doing?
Plug the sensor in??
Old Oct 2, 2005 | 08:49 AM
Darren P's Avatar
it is not doing anything and it is pluged in
Old Oct 2, 2005 | 10:05 AM
69firebird's Avatar
hmm, going to be interesting to see what the solution is for this
ed
Old Oct 2, 2005 | 11:30 AM
BoostMluse's Avatar
Does it light up at all? It should light up at least, then you should get some dashes across the LED readout. If not, you've definately got a power or ground issue. Mine works great.
Old Oct 2, 2005 | 11:54 PM
Darren P's Avatar
it was the fuse
I checked it and it looked fine but when I put a test light on it, it was dead
it works fine now
I had a 1 amp fuse and should of had a 10 amp
crossed the wires with the turbosmart it needs the 1 amp fuse
