Results from tonights STS runs...
Keep in mind, his best 60' was like a 2.4 or something and as Dennis (our track announcer and friend) noted, he was spinning all the way through 1st, and most all of second, not to mention the 2-3 shift put her sideways more than once Embarassed
Adjusted:
Fueling, noticed the AFR around 12.0:1 on the way to the track, so richened her up some more. I am not sure exactly where we want it, but I know that 12:1 is a little lean for a stock bottom 8lbs of boost turbo LS1. Wasnt able to log the AFR, using Larry's LM1 forgot the EIO interface cable to piggyback onto the HP Tuners logging Ugh..
Timing, was able to add in a couple more degree of timing. Max now is around 13*, which can probably come up to 18 once he gets the #15 Meth Nozzle in.
IAT's, with meth we logged a steady 7-10* increase per lb of boost over 5lbs. Used to be ~105 on 5psi, logged 113* @ 6psi, 127 @ 8psi...we kind of decided to skip 7psi Wink Add fueling for temps above "X" IAT, to reduce chances of KR, also reduced timing with "X" IAT.
Next time out, hope to have the larger meth nozzle in place, some race gas mix, and some big bad sticky tires to hook at the line under 5-8psi boost. I am pretty happy about it and I believe Larry is too, well after scrapping the **** out of drawers from the new tune and oh yeah the addition of a 3800 2.4str Stall.
Run down of the setup:
2002 35th SS 1LE, add STS with T67 upgrade, and a Fuddle Racing 3800 2.4str TC, Walbro 340 intank, 42lb injectors, TR-6 plugs.
Next mods should include, addition of sticky tires, some suspension work, LSX 78 or 90mm setup, headers and Y pipe, 918 springs, hardened pushrods, maybe a small turbo cam
Hopefully some weight reduction too, this thing is a pig compared to my 3260# car. Cant wait to get some decent track prep (yeah right!) and some tires to match to get out of the hole on boost! Starting to like the tuning the turbo routine.Charlie
Elevation is about 6pack more than the ocean, but our DA was up around 3000 or so last night. We're getting feedback in form of rain and the trade winds lacking their push from the tropical depression from last week, and this weeks Trop. Storm Kenneth.
As for the missfires, what is your plug gap. If it's not .030 then change it. I have mine at .031 right now and am blowing out the spark at 12-13 psi so now i'm going to .025.
Did you change the Advance vs. IAT at all? I put in some -x advance based off the meth running out, having issues etc, or getting too high IAT's.
Also added fuel the same, vs IAT's.
TIA,
Charlie
The STS meth kit sprays after the IAT sensor which is dumb in my opinion. You should reroute it to spray before it for best results.
BTW, I trapped 126 on 13psi t67 with 4600 DA here in vegas. Our track is at 2200'
