link to pump voltage booster?
Old Jun 3, 2002 | 06:31 PM
MIGHTYMOUSE's Avatar
Default link to pump voltage booster?
and who has the best price on them? i need a good intermediate setup with the 42#'s before i go big (no not harlan big)
looking for 600 rear wheel on stock lines and walbro gss340 (255l hp/hv)
<small>[ June 04, 2002, 10:16 AM: Message edited by: MIGHTYMOUSE ]</small>
Old Jun 3, 2002 | 07:01 PM
Phate's Avatar
Default Re: link to pump voltage booster?
Try this volt blaster ...I think that your other alternative is the Kenne-Belle Boost-a-pump, but that will run you significantly more $$$.
I have the BAP and it works great...I got the 30A model and I plan on using it to boost the voltage to two Walbro GSL392 pumps if I need more fuel (this should be good to 900-1000 rwhp!)
Scott
Old Jun 3, 2002 | 09:24 PM
cablebandit's Avatar
I second the boost a pump. If you can get somoene to order one with you, you can get it cheaper...like 50 bux off
Old Jun 4, 2002 | 10:15 AM
what does the kb amplifier do that this volt blaster does not do? and can you rout the exess voltage from the blaster to the pump only and not fry all the other electronics connected to the alternator... its much better price wise!
p.s. my pump already sees straight alternator voltage (14 by my voltmeter on board)
Old Jun 4, 2002 | 11:46 AM
Phate's Avatar
Yes, the excess voltage only goes to the pump with the KB BAP. It does run ~$230 or so if my memory serves me, so it is quite a bit more expensive. I bought the bigger unit so that I could use it on two pumps at the same time because I knew that I was going to go dual externals.
I think that Harlan had the volt blaster on his car, and we know that he is a whiz...maybe he had his wired up so that it would only boost the voltage to the pump. You might want to check with him.
Good luck and let us know what you decide,
Scott
Old Jun 4, 2002 | 10:03 PM
RedDog's Avatar
I'm looking to purchase one very soon for my supercharged truck. I was looking at the MSD fuel pump booster, but didn't car for $230 tag.
