v band question
Old Oct 3, 2005 | 04:45 PM
DMH Fabrication's Avatar
Default v band question
Do they make a 5 1/4 or 5 1/2" v band? I had picked up a 5" from precision but it seems to be just a hair too small. It will go around the 5" downpipe v band flanges but the bot is about 1/2" short. I looked on a few sites and all i have seen are 5" and 6" v bands. Thanks for the help guys.
Old Oct 4, 2005 | 06:03 AM
BTL FED's Avatar
yup yup http://www.boostedsystems.com/produc...3f4b40d9fafc5b
Old Oct 4, 2005 | 01:19 PM
Alright cool. Thanks again for the help.
Old Oct 20, 2005 | 08:45 PM
update: the 5.25" came and it was identical to the 5" i ordered so thats still not big enough. Is there a 5.5" clamp? Precision told me 5.25/5" was the biggest but its still not as big as i need.
Old Oct 21, 2005 | 05:36 AM
smokinHawk's Avatar
what turbo do you have, i would think its a common flange, where the 5" would work?
im guessing its a thumper turbo with a 5" discharge, can you post any pics of the problem.
Old Oct 21, 2005 | 02:12 PM
This clamp is for the 5" down pipe. I already have it clamped to the turbo fine. I had the vband clamp kit when i welded the flanges in the down pipe but the v band itself got misplaced over the year the car has been apart. i can get a pic of the vband flange on the down pipe if it would help. It measures 5.25" out side to outside.
Old Oct 28, 2005 | 10:16 PM
ok here is a pic from outside to outside. What size do i need?
Old Oct 31, 2005 | 07:21 PM
ttt..
Old Oct 31, 2005 | 07:31 PM
oange ss's Avatar
are you sure it's a v-band and not a u-band ?
Old Nov 1, 2005 | 08:43 PM
looks identical to the 5" vband flange i used on the turbo except this one is bigger
Old Nov 4, 2005 | 12:08 AM
upppp
Old Nov 4, 2005 | 05:49 AM
smokinHawk's Avatar
what turbo is it? have you contacted the turbo manufacture and see if they have one?
could it be an odd sized Vband flange and not the turbo?
have you tried these guys http://www.airflo.com/
call them and see if they have a clamp for your specific turbo.
Old Nov 7, 2005 | 05:35 PM
not for the turbo. The down pipe is 3 pieces and uses a vband to hold it all together. Its just a really big vband and precision turbo didn't have it and did not know where to get one.
Old Nov 7, 2005 | 09:32 PM
smokinHawk's Avatar
can you cut it off and weld some new vband flanges to it?
might be your only option if you cant find the clamp
Old Nov 8, 2005 | 09:24 AM
why would i want to use a vband smaller than the exhaust pipe and restrict the flow? Someone must still sell the clamps since it had one before.
