ATI guys I need some help, please!!!!!
Old Jun 21, 2002 | 03:02 PM
scottywheels's Avatar
Default ATI guys I need some help, please!!!!!
I have the p-1sc-h, I have the 3.25 pulley on it right now and was seeing 6 psi. I have since done a full motor at cartek with 9-1 comp, je pistons,cam, heads,header and the hole 9 yards. With the lower compression I want to run the blower at 10 psi of course on 94 octr using ls1 edit for my management with a fuel sytem and 50 psi injectors.
What I need is what do I need to do in order to run that amount of PSI and can the blower spin that much, Im trying to do this without upgrading to the d-1sc. ATi said they have a 3.0 pulley but ill prolly only see like 7 psi because of the flow now. what do you gys think I should do?
Old Jun 21, 2002 | 03:17 PM
Black LS1 T/A's Avatar
Moderator
Default Re: ATI guys I need some help, please!!!!!
Call Golden West Performance about their 8-Ribbed system which includes larger crank pulley. That should get your boost up AND reduce slippage.
303-346-5232 and ask for Jason. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jun 21, 2002 | 09:53 PM
what do you think I could spin it at with what I have and I dont want to go over the rpm max and burn it out. can I get 10-12 psi out of it?
Old Jun 23, 2002 | 12:50 AM
Moderator
I don't know. I'd hate to guess.
Call ATI and get an answer from the horse's mouth. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
