100 octane aviation fuel
Old Jun 26, 2002 | 10:11 PM
Stab & Steer SS's Avatar
Default 100 octane aviation fuel
I found out the airport across the street from work has 100 oct.What are the differences between 100 oct aviation fuel and auto fuel.Does it have any ill effects on the fuel system, o2 sensors, piston rings etc?
Im posting here because fueling is so important to you guys.
Thanks,Chris
Old Jun 26, 2002 | 10:30 PM
jhelms's Avatar
Default Re: 100 octane aviation fuel
I am not an expert on this topic BUT have heard that the gas is formulated different because of the affects of needing to burn properly at those MUCH higher altitudes.
So I've always been told NOT to run it, maybe someone else can add in some more logic to back that up though...
Old Jun 26, 2002 | 11:15 PM
2bseen's Avatar
11 Second Truck Club
It might be leaded.
Old Jun 27, 2002 | 01:28 AM
horist's Avatar
I would say don't use it... I'm sending an email to a coworker now (computer programmer but used to work at Migs Airport in Chicago)
will let you know what i find out
Old Jun 27, 2002 | 02:02 AM
slow's Avatar
100LL is a common airport gas, 100 octane, low lead.
I filled up a friends plane with this at sebring, (2 stroke, rotax powered) and did not like running leaded gas <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> )
Ryan.
Old Jun 27, 2002 | 06:00 AM
2001bird's Avatar
you can run it when you go to the track, just swap in a pair of junk o2 sensors.
Old Jun 27, 2002 | 09:53 AM
horist's Avatar
Talked to my friend, here's his reply:
"Yes. A guy I worked at the airport with used to put it in his Mustang every once
in awhile. We all used to back our cars up to the fence at night and fill up on
free gas. Prop planes have 4 cycle engines just like cars.
Old Jun 27, 2002 | 07:14 PM
Thanks guys! Supposedly its unleaded. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jun 28, 2002 | 08:38 PM
RAGENZ28's Avatar
MY FRIEND RAN AV GAS AND HAS A NICE HOLE IN HIS PISTON TO PROVE IT, BUY RACE CAR GAS GAS IS CHEAPER THAN NEW MOTORS
Old Jun 29, 2002 | 01:09 PM
JP's Avatar
JP
Just a warning,Av gas is not good to mix with Nos.
Old Jul 13, 2002 | 10:47 PM
cdk4219's Avatar
Aviation fuel is definately formulated for planes and not cars. While auto engines will run on it you will probably see a loss in power as opposed to running ultra 94. In higher HP applications running AV gas is detrimental to driveability and engine longevity.
