went to the track with new motor ......results....
<small>[ July 01, 2002, 07:51 AM: Message edited by: cablebandit ]</small>
2.10 60'
7.8 @ 98 MPH 1/8-mile
12.0 @ 125 MPH 1/4-mile
Let's look at my best run:
1.65 60'
7.07 @ 99.49 MPH 1/8-mile
10.98 @ 125.83 MPH 1/4-mile
Let's see...
2.10 - 1.65 = .45
hmmm...
125 MPH trap speed after THAT inital work? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Dude... I don't know what your boost issues are. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> But, I'd say with a tune and proper holeshot, you are sitting on top a MONSTER! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Work it out and post your success story. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Ross 9:1 pistons....on stock rods with arp bolts
stock crank with gm/clevite bearings
01 ls6 cam with matching springs
midly ported stage 1 heads..he did the bowls....i did the exhaust ports...stock valves
ls1 intake (ls6 on the way)
stock rear 3.42
ram clutch
stock maf
I have a pretty good tune....just need to do some exhaust work on the downpipe and crossover pipe before any more boost will do me any good. After the exhaust work, it will get interesting <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I was happy with the trap speeds considering the et info
What did you dial your boost at?
what octane you using?
when i get my heads back on i'll be at 9.2:1
i hope i can run some good boost llike you.
On the boost loss, is it just less in each gear or does it drop off as the rev's come up?
Are you running an adjustable boost controller or just the deltagate?
It is good to know that a 9:1 motor w/ mild heads and cam can turn 125. Now if i can get my car finished we can see what a 8.7:1 big cam setup can do on 15 <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
ross 9:1 pistons with stock rods and arp rod bolts. These were from ARE...1100.00 and you get 100 back when you send in your stock rods. I am very pleased with this part.
Cometic head gaskets (boost ready) 100 bux each.
I think the new Gm mls gaskets would be fine but I'm not as patient and methodical with tuning as Harlan so i needed any extra insurance. happy with these as well....and are reuseable!!!!!
01 ls6 cam/springs. If you don't work on any of the turbotech exhaust, I THINK you might as well stay with the stocker. I lost some bottom end torque. I'm sure some is from lowering compression but some from the cam. I think the 6.0 truck cam would be better in my current setup. The motor just cant breathe over 5500 with the kits exhaust setup so might as well keep your bottom end torque.
Jwis timing chain from katech with stock gears. This thing is looser than my stock 46000 mile chain. 110.00 bux and this i'm not happy with. I shoulda gone with a stocker or maybe something else.
my heads....hmm....with the stock turbo kit....keep yours and just get some springs. Harlan made great power with the stock heads.
Arp head studs....200 bux...no problem taking off heads on the car...I'm happy with that.
Got bearings from gm (mains) and clevite rod bearings.
Used stock main caps...bolts....even my stock oil pump. Now I know people are gonna flip when they hear that I kept my stock oil pump. With the crapshoot concerning ls1 oil pumps, I decided to just use mine that was working fine. I reused all gaskets except for head gaskets of course. No leaks so far. I tried to do this cheaply when possible. My car is not going to run with Harlans but I'm still gonna have a lot of fun with it just the same.
Give me a call today man. I have those race pipes you were trying to buy. If you still want them I will hook ya up. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
BTW, The SS is about to be on Dr Gas X pipe and dynatechs. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Jerry forged motor <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Rons stock bottom end <img border="0" alt="[Camaro]" title="" src="graemlins/camaro.gif" />
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Ron..will call. yeah you'll be faster but......i'll be slower <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Harlan the boost would do my normal spike to 14 then settle at 10.....next gear spike to 12..settle at 8.....10 then 5....it was way weird. I think the tt kit comes with a racegate. Im using that along with a ball/spring type boost controller. Worked good up until Sunday. Then it went nuts. On the way home Sunday night, a ricer was riding my *** on an entrance ramp. Boost spiked and held at 15 psi (i'm expecting 10) and I damn near lost the car...it was MOVING!! Just gotta get that curve flatter in the upper rpms...screw the peaks...i want area under the curve
