FP ?
Old Jul 6, 2002 | 12:06 AM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default FP ?
I was wondering this just now what if I just set my fpr to 60psi and dont hook up the boost ref. Will I still have enough fuel for 7psi with spikes up to 9 on shifts? I have #42 lb injectors with the incon supplied intank pump. Till I get a new FPR atleast.
Old Jul 6, 2002 | 05:20 AM
cablebandit's Avatar
Default Re: FP ?
only a wideband will tell...or you could just watch atap and look for sub .900 on your o2s and monitor KR
Old Jul 6, 2002 | 11:03 AM
red ws6 99's Avatar
Default Re: FP ?
Assuming you start out at 60 psi and have 9 psi boost with no boost reference then 51 psi fuel pressure at full boost would get you 650 fwhp at 100% duty cycle with the 42 lb injectors.
I guess you still have your aeromotive hooked up to the boost/vacuum line instead of the just boost (you could put a vacuum regulaotr on the line and get 1:1 instead of 2 or 3:1 like your getting). Of course with just boost reference it does not really rise anyway.
Gary
Old Jul 6, 2002 | 09:47 PM
Cool28's Avatar
Default Re: FP ?
dumb question what is fwhp? That crank I figuring. I want to get another pump also with a FPR.
Old Jul 9, 2002 | 12:09 AM
red ws6 99's Avatar
Default Re: FP ?
Yes fwhp is the crank, everyone has a big fit on figuring out rwhp. I would assume like 18-20% loss but some people say its a lot less.
Gary
Old Jul 10, 2002 | 01:03 PM
Black LS1 T/A's Avatar
Moderator
Default Re: FP ?
Here's one guy's spin:
"Obviously, another factor to consider in this discussion is how accurately the manufacturers rate their own engines. It's hard to believe that the Corvette and Neon could lose 17 and 22 percent of their engine's horsepower in just frictional losses. Most experts agree that a 10 to 15 percent loss is normal. This does not necessarily mean that the manufacturers are lying. The additional drop could come from a number of causes including variations in engine performance and dynamometer readings. It could also be that the manufacturers are dealing with an expertly tuned engine's running under controlled conditions in a laboratory rather than a mass-produced engine that was put together on an assembly line and sold at a dealer's lot."
The whole write-up is at www.Edmonds.com :
Horsepower: Gross vs. Net
http://www.edmunds.com/ownership/tec...5/article.html
