Vortech crank pulley removal?
Old Jul 15, 2002 | 06:24 PM
CoopDog's Avatar
Default Vortech crank pulley removal?
What kind of puller do you need to remove the Vortech crank pulley? I don't know if I can find a 3 or 4 leg puller big enough for this. Has anyone removed the SC pulley and then just used a conventional Balancer installation/removal tool?
Old Jul 15, 2002 | 08:19 PM
2bseen's Avatar
11 Second Truck Club
Default Re: Vortech crank pulley removal?
just use the 3 arm puller you can get one at autozone. You just hope they didn't use red locktite and it lock real good. I couldn't get one off with torch on it and pull bar had to leave it on the old car and buy a new one btw use what ever you have to if you are selling car the pulley is $1000 from vortech.
Old Jul 15, 2002 | 08:24 PM
CoopDog's Avatar
Just taking it off to put on a new engine. I put it on initially, I don't think I used locktite, can't remember though. I'll go to an autozone to see what they have.
Old Jul 15, 2002 | 08:45 PM
SJH's Avatar
SJH
you use a conventional 3 bolt harmonic damper remover.Remove 3 of the long bolts holding the pulleys to the damper and use those for the puller.
I have had mine on and off a dozen times.
Also ,mine spun and gouged up my snout before I keyed the crank.
Steve
Old Jul 17, 2002 | 12:42 AM
CoopDog's Avatar
Thanks SJH, thats what I wanted to hear, I can do that. I don't know if mine is spun or not-don't think so, but it is going on a new motor anyway that has the crank keyed.
