Process of building engine
Old Jul 17, 2002 | 06:47 PM
AlienDroid's Avatar
Default Process of building engine
I'm getting forged 8.5:1 pistons,rods,crank,iron block,basically the only thing I'm going to reuse from the old engine are the heads.
It's going to be bored, stroked and turboed.
408ci, port and polished heads and turbo cam.
What do you guys think this will put to the ground NA? Because I have to save up for the turbo now.
<small>[ July 17, 2002, 06:49 PM: Message edited by: AlienDroid ]</small>
Old Jul 17, 2002 | 07:35 PM
LiquidSnake's Avatar
Default Re: Process of building engine
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by AlienDroid:
<strong>I'm getting forged 8.5:1 pistons,rods,crank,iron block,basically the only thing I'm going to reuse from the old engine are the heads.
What do you guys think this will put to the ground NA? Because I have to save up for the turbo now.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What kind of trany and rear end do you have?If you have a stock A4 and 10 bolt better start to save up like me <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 22, 2002 | 12:46 AM
Black LS1 T/A's Avatar
Moderator
What Turbo are you going with?
Old Jul 22, 2002 | 06:08 AM
smokinHawk's Avatar
depending on the cam it could put 450 to the wheels (N/A)
<small>[ July 22, 2002, 06:09 AM: Message edited by: smokinHawk ]</small>
Old Jul 30, 2002 | 11:30 PM
AlienDroid's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by smokinHawk:
<strong>depending on the cam it could put 450 to the wheels (N/A)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">even if I keep max hp below 6000rpm?
I'm going with a cheap used t60 kit first to start off, then I'll change out parts and build it up slowely. I'd like to have a t88 in it someday.
