Turbo 60fters
Old Jul 28, 2002 | 07:32 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default Turbo 60fters
The best I can get is 1.8. Just wondering if anyone else is 60fting better.
<small>[ July 28, 2002, 07:33 PM: Message edited by: Cool28 ]</small>
Old Jul 28, 2002 | 09:04 PM
Brady's Avatar
LS1Tech Sponsor
Default Re: Turbo 60fters
I went out last night and had trouble getting a decent 60' myself.
It wasn't spinning, it was hooking then bogging!
I'm launching off a 2-step with a 3k pill. I'm not "matting" the pedal because I don't want to leave at full boost <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> but I was able to make it 60' (in order) 1.62, 1.54, 1.49 buy increasing the boost at launch. I am using a tranny brake FWIW, but Harlen's 2-step should help immensely if you don't already have one.
Why won't your car 60'? spinning? bogging?
laterz
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Jul 28, 2002 | 09:23 PM
Cool28's Avatar
wasnt spinning. Guys there said it would haul *** after the 60. It did feel like a bogg come to think of it. I might just get a 2 step after I figure out this fuel problem.
Old Jul 28, 2002 | 09:24 PM
y2khawk's Avatar
Best i ever did was a 1.58, but that was on stock suspension and 10 bolt.
When the 12 bolt went in w/ the SFC's and LCA's i could never get below a 1.8
When i upgraded my torque arm, that helped alot. Finally getting the pinion angle where it needed to be netted some decent low 1.7's
Best to date is 1.69
I launch with 0 boost however. Thus the reason behind the 2-step. I needed that 300 RWTQ torque difference between 0 boost and 10 psi.
Based on my data logs it was taking .7 to .8 seconds from launch at 5800 (clutch dump) to build full boost. That's a good part of the 60' <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I'll know soon enough if the 2 step is gonna do it's job.
Old Jul 28, 2002 | 09:36 PM
Cool28's Avatar
Hmm guess its time to buy a 2 step <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 28, 2002 | 09:38 PM
Brady's Avatar
LS1Tech Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I'll know soon enough if the 2 step is gonna do it's job.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm telling you, it will do the job. I'm sure that you'll find the fine line between bogging and spinning, you'll be able to adjust the 2-step to leave at whatever the track can handle. Of course, a $500 boost controller wouldn't hurt either..
My local track was hooking great Saturday night and I ran (in order) 6.07, 5.93, 5.92**, all at around 110 mph. I just kept increasing the boost at launch and track held it. I'm running 28x13.50 QTP's FWIW.
** My local track is somewhere around 600' long, you should add .30-.35 seconds to my E.T to get semi-accurate 1/8 mile times. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
__________________
2016 Z07 Carbon
Old Jul 28, 2002 | 10:34 PM
y2khawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Brady_96Z:
<strong>My local track is somewhere around 600' long</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">damn red necks <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
you coming up for woodward?? I'll have my car running by then if it kills me, and i'd love to check out your setup. I'm sure HRH will drag you out that week <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 29, 2002 | 01:06 PM
cablebandit's Avatar
I had a few 1.70s launching at 5500rpms. Hopefully the 2 step will help that.
Old Jul 29, 2002 | 03:54 PM
Phate's Avatar
My best 60ft this weekend was a 1.9x ... the car was having some problems on the big end, but I managed a 11.96 @ 120 on 4psi.
I wanted to turn it up, but the boost controller wasn't working <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Scott
Old Jul 29, 2002 | 04:26 PM
zturbo's Avatar
The two step imo is a great thing. IF you can get the car to hook use it. I used it with my manual and loved it. I was going to rig it with the clutch safety switch on the pedal but found that it might screw up a little. I am now setting it up with the transbrake. Its nice to leave the line in a manual with 17psi granted it does nasty things to everything behind the motor <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
My car seemed to like the rpm set higher than i really liked to leave on though (liked it right about 5500) <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" /> <--you with two step <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jul 29, 2002 | 05:28 PM
Cool28's Avatar
ok give me all the details. How do you set it on a auto and do I just mash it when the yellows start to come down? You will be probably gettin a e-maill soon for me to by one <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 29, 2002 | 08:22 PM
zturbo's Avatar
For an auto you can do it a few ways.
1.Set it off the brake pedal When brake pedal is fully engaged have the trigger flip.
2 set a switch on your steering wheel with the 2 step and maybe a line lock then stage the car that way if the fronts will hold that is.
3 have a switch somewhere that you hold and when you release the brake release the button.
For me... I would get ready when both cars are in the beams I would mat (full throttle) the car. Boost would go almost immdiatly up to full boost. You can play with the throttle then to get it down.
On a auto though I would think you should be able to build boost when you floor with the brakes engaged anyhow...
Do you have a converter?
Old Jul 30, 2002 | 10:34 AM
Rpm2800's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by zturbo:
Its nice to leave the line in a manual with 17psi [/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You mean you left the line with 17 psi, with a T56? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Or can you clarify?
Old Jul 30, 2002 | 01:07 PM
Brady's Avatar
LS1Tech Sponsor
I think he attempted to leave the line at 17psi w/a T56.. kaboom <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
j/k Steven, but I seem to recall some major havoc to the drivetrain after your T-76 upgrade.
...Brady
__________________
2016 Z07 Carbon
Old Jul 30, 2002 | 09:25 PM
rod442's Avatar
At a couple of tracks where I could actually get it to hook; I have gotten several 1.67 60's and a few low 1.7's.
26/1150/16 et streets at 14 psi cold, hal shocks on 1 frt and 5 rear. do a big bunrout, Dump the clutch at 5500 and hold on.
Now that I am having clutch issue's I haven't been back to the track. Last couple of launches the clutch would only come halfway off the floor after a good launch. Not sure whats causing it yet.
Old Jul 30, 2002 | 11:03 PM
zturbo's Avatar
Havoc You could say that lol
Yanked tired on the street with the two step and a t-72q trim.
Loaded up car and went to the track unloaded and had a horrible day to start battery died (someone forgot to turn interior light off doh)
But then go to the line staged built boost built even more boost launched moved a wopping 12 inches granted the front end was on its way up but then the Torque arm, drive shaft, and rearend exploded oops did I do that.. load car on trailer and head to bar lol. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I hear ya brady <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> it is all good i just am building this thing to take king kongs motor
<small>[ July 30, 2002, 11:03 PM: Message edited by: zturbo ]</small>
Old Jul 30, 2002 | 11:09 PM
AlienDroid's Avatar
I thought the 2-step was for manuals, because you need to operate the brake, clutch and gas all at once to build boost off the line, and we ain't got three feet.
Old Jul 30, 2002 | 11:35 PM
BOOSST's Avatar
my best 60 is a mid 1.8 with about a 4500 launch. i have ordered the two step and hopefully will get it this week. how hard is it to put on and how much do you think i will drop my 60?
Old Jul 31, 2002 | 08:48 AM
I'd like to see if someone has tried this with a turbotech kit. I may be the guinea pig <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I want to see how it performs with an aluminum flywheel. If the flywheel doesnt launch ok, I will change back to a stock flywheel. My question is where do you start to see boost....would be nice if you could lauch at 4000 rpms with 4-5 psi
Old Jul 31, 2002 | 11:48 AM
BOOSST's Avatar
i am using the turbotech kit at 9lbs with good gas. hopefully i will get the 2 step on this week and see how it works <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
