STS Kit questions...
Old Oct 8, 2005 | 07:36 PM
NYSS Guy's Avatar
If you're going to upgrade the motor the 67 might not be enough. I am going with a GT76 for mine. The guys at STS can help you decide which is best. What you might be able to do is go with the larger turbo for now, but a smaller a/r to help the boost build quicker. Then, when the motor is donw, just change the housing to keep up with the flow demands. I'm not an expert on turbo's, but I think that might be a good way to go. Call STS, they can help.
Old Oct 8, 2005 | 07:37 PM
PHiL2's Avatar
Thanks for all the input man I really appreciate it!
Old Oct 10, 2005 | 10:30 AM
PHiL2's Avatar
Is the oil pump loud with the kit...like annoyingly loud in the car?
Old Oct 10, 2005 | 11:34 AM
socalstreetracer's Avatar
I hear mine a cold start up for about 1-2 minutes then I cant hear it anymore
Old Oct 10, 2005 | 06:10 PM
PHiL2's Avatar
Will my current cam be a problem?
Thunder Racing Custom Camshaft - 224/224 .563/.563 112 LSA 1700-6600 RPM Power Band
Old Oct 10, 2005 | 10:54 PM
NYSS Guy's Avatar
From what I understand, your close LSA of 112 will lead to boost bleed off. I THINK. Like I said earlier, I don't know cams that well. But my new cam is going to be on a 116 lsa. And that's a custom grind from someone who knows cams. I don't think it's gonna hurt you too much, it's just not ideal.
